| | | Forums66 Topics128,034 Posts1,055,546 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2017 Posts: 53 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 53 | Well my project is getting close to street-able. Not done but drivable. It's a 49 GMC 1/2 ton with a SBC with long tube headers and 700r4. I'm 2 years in on the frame off build. I want the final exhaust to be relatively quiet. A bit of a low rumble when accelerating is fine but quiet while cruising in the city or on the highway. Any suggestions would be appreciated . I have a 69 Camaro that has the typical muscle car sound at idle , the lopey rumble and quite a bit louder while accelerating. I don't want that for the truck. | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | In the muffler business, they call them Cadillac mufflers. Full flow, but whisper quiet while puttering about. You do hear what's going on when you step into it though. I have them on my '49 3100 with a 350 with just a bit of a cam in it. The muffler shop should know what you are looking for if you tell them "Cadillac mufflers".
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | How about a couple of the real Smitty's. Have two on my hot 350 in my 37. They have "burned out" a little now and sound sweet but not obnoxious at all. | | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | I put a magnaflow 20 on my truck and love the deeper sound. I get many compliments. | | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | The muffler Carl is talking about was used OEM on mid-1970's Cadillacs with 472 or 500 cubic inch engines. It has 2 1/2" pipes in and out, and using two of them in an exhaust system for a relatively small engine like a 350 gives virtually no back pressure and a pretty quiet sound. I built up a 318 Dodge engine for my son's pickup several years ago for just the sound you're looking for- - - - -quiet cruising and just a little bit of bark on hard acceleration. Jerry
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | Go here for sounds.. They test each of their mufflers. I have a 40 0n my 54 235, duals.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | Dual Dynamax's on an SBC 350. 49 GMC with dual Dynamax | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Stock Dodge 6bt on '37 GMC with DD, quiet yet can hear.
Ed
