1 members (RLB), 116 guests, and 2 robots.
Topics128,090
Posts1,056,378
Members48,442
#132043 07/04/2004 7:47 AM
I have a oil leak coming out of the speedometer
housing that fits in my 700R4 tranny. I put in
a new O ring, but it still leaks. I can't seem
to get the housing in there tight enough.
Anyone else have this problem and come up with
a solution. Maybe I can double up the O rings
and that might work. The trouble is the bolt
and bracket that hold the housing in place are
not made to put much force on the unit.
Cecil.........
#132044 07/04/2004 3:17 PM
When you get it figgered out, let me know. Mine appears to be leaking around where the gear passes thru the housing. All new GM stuff, I even put another seal on gear, still leaks some. Just enough to leave spots on the floor. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#132045 07/04/2004 9:20 PM
Exactly, mine is almost new too. If you find
the answer before me please post it or contact
me.
#132046 07/05/2004 8:46 AM
There is a seal inside of the housing where the gear shaft comes through.they like to leak and a lot of times you think it is the o ring.check that and see what it looks like.
48GMC 5window,350,700R4,p/w,p/b,and a couple of homemade parts!
41 Sedan Delivery next up to be reborn!!
"Nothing is Junk,just unfinished projects" Desert rat with a spray gun!
#132047 07/05/2004 1:03 PM
yes there is probably a little lip seal inside the housing the same as on th-350 i remember them doing rebuilds on those trannies.
#132048 07/05/2004 2:04 PM
I put two seals on the gear, seemed to slow it down but still seeps some. All new GM stuff, & it leaks. Brian
#132049 07/05/2004 9:27 PM
Junior Member
Junior Member
I have the same problem on a turbo 350. I had it rebuilt by AAMCO. Since they rebuilt the tranny by itself, I have to get it inspected by AAMCO once I can get my truck on the road. I will mention it to them and get back to the board when I find out their solution.
Richie West
#132050 07/06/2004 5:24 AM
I will replace the seal and ring and see what
happens. Thanks.
