1 members (Shade Baby), 152 guests, and 8 robots.
Topics128,106
Posts1,056,214
Members48,436
#1319517 07/28/2019 2:55 AM
Been noticing a gas smell in my 37 and looked at the cap and noticed the seal needs replaced so would a O ring work.
I think that it would, I am a retired firefighter and I had some extra 1 1/2 hose coupling gaskets and they work like a charm. Stop by a fire station and see if you could trade a pizza for some gaskets.
1936 GMC T-14 1/2-Ton Pickup
1 Offline
Make sure the vent is not plugged up. I ran a piece of heavy duty monofilament up the vent tube.
Trombones Totem Poles And Old Trucks!
I improved the "gas smell" by extending the vent tube slightly out the bottom of the gas tank. This puts the bottom of the vent below the cab sheet metal. First I took a bronze firearm bore brush to clean the inside of the vent tube at the bottom. Then I took a one inch length of 1/4 inch brake line, beveled one end slightly and epoxied it into the vent.
I had disassembled the vent apparatus and studied the design. There is no way that the cork ring is going to seal the vent holes completely in the event of gas sloshing up against the holes. So it is inevitable that gas will drip from the vent and when you are driving fumes are going to blow into the cab environs. This must be why GM abandoned the design after one year and in 1938 returned to the gas filler outside of the cab.
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
I have found good quality replacement gas cap gaskets for various applications (measure and compare) here
https://realgaskets.com/product-category/fuel-caps/
•1952 Chevrolet 3800 pickup
---All pictures---
Found a box of big O rings in the garage and found one that fit,it looks like I will need a 2 1/ ID/2 5/8 OD gasket.
