8 members (Otto Skorzeny, Steelonsteel, Gdads51, J Lucas, Peggy M, dt235sd, walter74, klhansen), 127 guests, and 3 robots.
Topics128,036
Posts1,055,454
Members48,422
#1318633 07/21/2019 2:37 PM
Good day all. I have a 62 235 and was pocking around the starter and I found on the block just above the starter 2 bars on the block . they are not like the 261 bars as they are less defined and about 2 inches apart. Is this then norm or is it a flaw in the casting ???
good planning is no substitute for dumb luck
panel fan #1318645 07/21/2019 4:04 PM
panel fan #1318659 07/21/2019 5:48 PM
Look for another set of captains bars on the other side of the block. That would indicate a 261
52Carl #1318665 07/21/2019 6:36 PM
Maybe . . . Maybe not?
panel fan #1318710 07/21/2019 10:36 PM
The best way to ID your engine is to tell us what the engine code is that's stamped on the machined surface next to the distributor...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
panel fan #1318814 07/22/2019 4:25 PM
oops right! block # is k3769716 ser # next to dist. is T- 666899 which matches the # on the I.D. plate inside the truck and the head is an 848 head .
there are no bars on the opposite side of the block. I have a 261 engine here and the bars on it look nothing like what I have on my existing engine.
I tried to post a picture , hope it comes through.
panel fan #1318885 07/23/2019 12:05 AM
2 Offline
when used in the USA anyway
block casting 3769716 is a 235 truck 1958-62, or a car 1961-62 - almost always with head 3836848
but.... the serial number is not like i would expect
could it be that its a USA cast block that found it's way up into Canada and got a Canadian engine serial.
the serial number format in Canada has virtually no information about the engine, it can be just 6 numbers, or 1 - 2 letters followed by 6 numbers.
if you post a photo of the serial number stamping, i can let you know for sure
GM Canada vs GM USA use different fonts stamps on the blocks, so there is no question who stamped it
do your 6 and 9s curl their tails or are they straight?
-s
panel fan #1318939 07/23/2019 12:50 PM
The 6 and 9 s do curl their tails and the truck was sold originally in Canada .
The research I've done in the past suggests its a 235 , but I have't seen those bars on any other 235's , they too might be a Canadian thing , I will have to look more closely when I check out other 235 's at car shows .
Thanks John
panel fan #1318966 07/23/2019 5:13 PM
2 Offline
makes sense, curly end 6, 9s is what the Canadian stamped numbers are like
i would be curious to know the engine color and the model ID tag info, because i haven't seen the T prefix before,
all my trucks engines are numbers only(replacement engine) , X or XC (on original engines).
-s
panel fan #1319013 07/23/2019 10:57 PM
model C3605 serial no. 2C3605616905B engine no. T-666899 and it's grey
On the tag it says made in Canada also a plate inside says a max gross weight of 7,800 lbs and an outside badge of C 30
My research suggests it was built in Baltimore and only the tag was made in Canada !!!!
panel fan #1319031 07/24/2019 1:44 AM
2 Offline
thanks for the extra info,
i think your research could be correct, until we find the secret canadian engine decoder ring we will never know for sure
-s
panel fan #1319052 07/24/2019 4:38 AM
What research has lead you to believe it was made in Baltimore?
Here's an example of 1962 Chevrolet US serial numbers;
2C365B100001
2 = year (1962)
C = Conventional Cab with gas engine
36 = Series (3/4 ton)
5 = Body type (Panel)
B = Baltimore
100001 = Unit number starting with 100001 at each plant.
Your model designation would be C3605S here in the US.
36 = GVW classification (3/4 ton)
05 = Body (Panel)
S = 30 Series ordered with optional 7800 pound GVW
I can't help with the engine number other than to say it's not a US format.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Mike B #1319095 07/24/2019 5:43 PM
The above info is the same info I had found leading to the Baltimore opinion. on the same sight I was lead to believe the T on the engine no. meant Tonawanda NY.
I suspect the parts were built in the USA. and assembled in Canada.
In the end I'm convinced its a Canadian 235 but those bars got me stumped if in fact they are bars and no blems from the casting procedure .
In the future I will be checking any stovebolts I see for similar markings .
Thanks John
Mike B #1319111 07/24/2019 8:31 PM
2C365B100001
2 = year (1962)
B = Baltimore
05 = Body (Panel)
Mike B smile
OK, did a little more digging and found the US serial number break-down to be very close to the Canadian...here's your Canadian serial number break-down;
2 = year (1962)
05 = Body type (Panel)
6 = Cylinders (4, 6 or 8)
16905 = Unit number starting with 00001
B = GVW (6,001 - 10,000 pounds)
Absent of a "plant" identifier it would seem that there was only one plant building trucks in Canada at that time.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
panel fan #1319392 07/27/2019 1:14 AM
Those are definitely not captains bars like any which I have seen on either 235 with powerglide nor on 261s.
It should be noted that I have not seen all of them. smile
panel fan #1319438 07/27/2019 2:02 PM
Well I guess I'll go with the notion that they mean nothing. Truck still runs , that's all that counts.
Hope to see in Winchester VA.
