5 members (TUTS 59, WICruiser, 2-Ton, jmoore, dunfire), 123 guests, and 1 robot.
Topics128,048
Posts1,055,541
Members48,425
#131740 04/15/2003 6:21 PM
Junior Member
Junior Member
I recently added power steering to my 52 chevy PU using a kit and steering sector from a 76 chevy truck. I decided to keep the stock steering column and cut it a couple inches from the firewall utilizing steering joints to connect to the sector. It works great, but I have discovered that I do not need that big ole stock steering wheel. My question is, is there a smaller dia steering wheel that will fit on the stock column? I have been told that back in the 60's they changed the number of splines on the shaft. So, what smaller wheel will work on my stock column? Any help would be appreciated.
Bill Pratt
When I got my truck it had what I believe to be a 70-something D*dge steering wheel, ugly as sin and smaller than stock. Combine this with a poorly adjusted manual steering box and 10" wide front tires and I could barely turn the wheel. It's much better now... grin
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
I used a 70's pickup column in my '40 as well, a s-10 steering wheel bolted right on. I did however have to grind the lower side of the hub to get it to slide onto the shaft far enough for my liking. I was told all later model GM splines are the same...so pick one you like.
I'm pretty sure your going to need one of those "Cal Custom" steering wheel adapters to install newer wheels.
Joe
The same spline on your 52 column was used by GM up through at least the early '80s. So any wheel from a Vega, S10 or most anything GM will slide right on. While you're at it, try moving the column a little closer to the dash, if your linkage allows - you'll be amazed by the extra room it provides in the cab.
So I might be able to convince a '54 GMC steering wheel to fit on a modern column? That would be very sweet...
1954 GMC De Luxe COE
