3 members (Gdads51, Ponchogl, mick53), 39 guests, and 2 robots.
Topics128,090
Posts1,056,018
Members48,430
#1313491 06/07/2019 11:44 AM
I am having a hard time finding a pair of 19.5 8-bolt rims for my 1959 Chevy 1-ton to complete a set of six with a spare. With this type of rim being used from 1956-1972, I thought that it wouldn't be too difficult to find some. I see Accuride is a supplier of new rims, do they produce an 8-bolt 19.5 rim with 1/2 inch lug holes? Am I overlooking a secret source of these rims?
1959 Chevrolet 3800 Pickup
1937 Chevrolet GC Panel
Can you still call it a barn find if it's your barn?
Kerwin #1313494 06/07/2019 12:13 PM
Consider also same wheel but with 9/16” lug holes. I’ve run those without issues on my 1 ton.
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #1313503 06/07/2019 1:13 PM
I was wondering about those but had concerns over the larger lug holes. What years/makes of the 9/16" lug would work? Thanks.
Kerwin #1313506 06/07/2019 1:50 PM
Pretty much GM
Any year you find them on, they were used sparsely enough and on somewhat less common things like step vans and RV's and even pickups that you should not limit your search for any particular model or year.
Instead look for the wheels, don't get all worked up about what they come on so long as they are the wheels you need.
With some practice you'll be able to spot a 19.5" wheel in a junkyard from 50 paces.
Not all 8 lug 19.5" dual wheels will fit over larger rear brake drums, more about that here
https://www.stovebolt.com/ubbthread...wheels-and-drum-fitment.html#Post1311972
As always test fit any wheel before deciding it is useful for you.
---All pictures---
Kerwin #1313507 06/07/2019 1:51 PM
Offline
Offline
A lot of step vans used those, and a lot of wrecking yards collect step vans for sheds. How many do you need?
My 1955 GMC 450 Dump Truck
Elderly Iron
"Performance" is the pursuit of a toy that won't break.
Kerwin #1313508 06/07/2019 1:52 PM
Offline
Offline
Ok, NOW I see "pair". DUH!
Elderly Iron
Grigg #1317108 07/09/2019 5:59 PM
Hello, saw these on CL...do these appear to be the correct 19.5 type? In reading past posts there appears to be some more cone shaped.
Kerwin #1317207 07/10/2019 12:31 PM
Hard to tell for sure from that perspective but I think they are the concave type that should work and not the conical type that don't clear the brakes.
In person or with a little bit of a side view it's very easy to tell.
---All pictures---
Kerwin #1317213 07/10/2019 12:53 PM
Crusing in the Passing Lane
If those wheels are nearby and your truck is mobile, just do a trial fitting, front and rear, at the location, or take one home for a trial fitting with agreement to return if not fit.
Ed
This set is a little far away in north central MN and I would be buying them with the help of a family member who wouldn't be able to do a fit up. Price is 4 with probably shot tires for $200. So far $50 seems to be the going rate if I even see them for sale any closer. I'm in SW Wisconsin, and any that I have been able to locate are a couple of hours away.
Kerwin #1317302 07/11/2019 2:55 AM
It'd be nice if the dead tires stay behind for that price.
---All pictures---
Moderated by  Dusty53
