2 members (Gray_Ghost, 1 invisible), 75 guests, and 6 robots.
Topics128,181
Posts1,057,185
Members48,465
Socket Breaker
Socket Breaker
1957 235 inline six engine.
Stock intake, has headers.
it is in my dad's '53 chevy truck.
What options are there for a carburetor?
It has the 1 barrel rochester... well, it's one barrel and it's a rochester( read here if u care to know: http://hardin.home.mindspring.com/1953/numbers.html )
Anyway, what options are there... new carbs, restored carbs... whatever.
Just wondering what folks have done before...
merely curious,
-W
the headers were a good start!.
you could go to a new intake manifold setup with small 4 barrel (be sure it has a water heated manifold). OR you could go for the cool factor. there is a company called vintage speed that has an adapter (about $90) that will go from your one barrel intake to a dual one barrel intake that looks SOOOOO cool. they also sell the complete setup with carbs, linkage and everything you need to install it (more than $90!). that way you dont have to try to tune dual carbs yourself. the owner is also a great help with setup and problems.
then consider cam, HEI, timing changes,etc ........ you know, all those $$$ things!
Socket Breaker
Socket Breaker
I don't think pop is gonna change the intake now that he has the water heated bit on there...
I was just curious as to what would 'bolt up. smile
Are there any modernish carbs that could be put on there, bolt on?
-W
Woog,
I like the Carter YF. Its what I have on my 216 and what I'm going to put on the new 235. I've posted the info on the rebuilder I recomend in the past.
Riding in the Passing Lane
I found a Roch. 1 barrel at a swap meet that had a larger troat. I don,t know what it was off of but it made a 235 run like an 8. Also the 68 up 292,s came with a 1 barrel mono-jet that was larger than the others. It would be agood one for it but you would have to change the throttle linkage. smile
1972 Chevy c10 Cheyenne Super
How about a 2 bbl adapter to go on the one-barrel intake and stick a 350 cfm Holley 2 barrel on it?
52 GMC 3/4 ton pickup
68 Big Block Vette
68 455 Firebird
I tried an adapter with a two barrel,not worth the effort.But I did open up the top of a stock intake,make a phenolic mounting flange and bolt on a Holley 2300 from a 266 IHC V-8 engine,just slightly smaller than a typical 350 cfm Holley. Major impovement on a 261,way better throttle response,better pull at all speeds and even the gas mileage is better.I believe the 2300 series Holley is a better choice than the Weber Holley butt ugly Pinto carbs.But this ain't exactly on a bolt on.
The Holley 1904 one barrel from a 225 slant six Mopar is a great improvement also.A bolt on,but the throttle linkage and choke needs some backyard engineering.Some 50's GMC 270's had a Holley 1904,should work as is on a Chevy
53 3100
1929 Ford Roadster Pickup
1934 Ford Pickup
68 Plymouth Satellite RR Clone 2 Door
My Fleet
I'd also suggest the Carter YF; specifically 3211S with electric choke. It was available for the later 235s and is a great all around carb.
Steve G.
1942 Chevrolet 1/2-Ton Pickup Truck
Check out Langdon's Stovebolt for the Holley/Webber two stage two barrel, has adapter to your intake. Not expensive!!!!!
1946 1/2-Ton Chevy
About $18 bucks, isn't it?
68 Big Block Vette
68 455 Firebird
Still, with the modern 2bbl Holley and modern idle circuits, power valve, increased cfm, I would think the improvement would still be noticeable over the Rochester's "dump the fuel in" 1 barrel. The cfm might not be as improved as opening up the top of the manifold as Truckedup did, but you still benefit from these other improvements. Wouldn't you?
68 Big Block Vette
68 455 Firebird
Socket Breaker
Socket Breaker
Thanks everyone.
Some more stuff got added to this post later I see.
Thanks for all the tips and suggestions.
-W
Socket Breaker
Socket Breaker
http://www.stoveboltengineco.com/acartpro/product.asp?productid=91
Adapter 1 BBL to 2 BBL
Price: $15.00
for Holley/Weber and Carter Weber Prog. Carb. (note: does not fit Rochester carb) Discount for dual and triple carb set ups.
This what ya'll are referring to?
-W
