7 members (fonz8261, Rexville48, 1955 1 Series, Peggy M, mk72, Shardean, 55shaker),
60
Mod | | | Forums66 Topics128,022 Posts1,055,387 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2019 Posts: 22 'Bolter | | 'Bolter Joined: Jun 2019 Posts: 22 | I've had my 1950 3100 with a 6v 216 for 3 years.
In that time I've done plenty of work on it but it's been running and driving the whole time.
So 2 months ago it stalled on me after driving for about 30 minutes. Had never done that before. It was flooded. I ran the battery dead trying to get it started. The next day, on a full battery, it started right up and ran fine for a short drive around the neighborhood. Got home and parked it. Hasn't ran since.
Figured it was still flooding so since I was gonna open up the carb to check the float I figured I'd rebuild it.
I ordered a rebuild kit from mikes carbs, followed every online video I can find.
After getting the carb straightened out and then rebuilding the starter (had a bad commutator) and running new battery cables, it won't start. It will crank and crank but i can't even get a burp or a fart out of it, even with starting fluid.
So I think my timing is off. I've tried fiddling with it for weeks but still can't get it to fire.
I'm hoping there is someone near by (I'm 20 min south of Annapolis) that has a compression gauge, vacuum gauge and timing light and the experience to help me get my truck back on the road. I'm missing out on the prime driving season.
I'll gladly provide lunch and drinks. Hell I'll get crabs and beers for the victory lap down the driveway.
Any help is greatly appreciated. | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | I am not the engine guy. I am the guy that will stand around and heckle the engine guy and enjoy the experience. Let us see if the engine guy and his entourage pokes his nose in. It sounds like a good field trip / rescue detachment. Welcome to the group. Hambone | | | | | Joined: Jun 2019 Posts: 22 'Bolter | | 'Bolter Joined: Jun 2019 Posts: 22 | Thanks I'm no engine guy either. I'm learning as i go. | | | | | Joined: Aug 2001 Posts: 3,588 Moderator | | Moderator Joined: Aug 2001 Posts: 3,588 | Sounds like a challenge for SWEET! If I was closer, I would stand by Hambone and help him.
Don 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | You can borrow free tools from AUTO ZONE. Also from Advance Auto PartsHarold
Harold Is a restoration ever finished? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | If you haven't messed with timing already I wouldn't suspect that being the difference between running one day and not the next. Do check for spark at a spark plug wire.
I'd guess (without seeing the truck) at this point that insufficient current/voltage is available to the ignition while cranking. You did replace battery cables, but what size, are connections bright clean metal, and where are they connected, the ground in particular? Best to run ground cable direct to one of the two starter mounting bolts unless you're dead set on being 100% original and if so this would be a good place to compromise at 99.5%. I recommend 2/0 cable for these trucks and 6V. If you have 1/0 that should be fine, but 2/0 is a nice amount of overkill without being ridiculous.
If the above is the issue it should roll start nicely as is. | | | | | Joined: Jun 2019 Posts: 22 'Bolter | | 'Bolter Joined: Jun 2019 Posts: 22 | 2 gauge cable, ground runs from neg terminal to a lug on the flywheel housing just above the starter where the braided ground lands. all connection points were sanded and bright and shiny before bolting them up Blue spark on all 6 plugs, gaps set to spec.
I tried setting timing per the manual. #1 at TDC on the compression stroke, rotor pointed at #1 wire. Points just barely opening, Octane setting set to zero Won't start. Swapped wires 180 out. Won't start.
Had my daughter hold down the starter and withe the octane setting bolt loose but tight enough to hold the dizzy in position i slowly advanced and the retard the Dizzy. Nothing. Still won't start. Change wires 180 and tried again, Nothing.
Each time there was gas in the manifold and a quick shot of ether in the carb. Key was on and choke was closed. Battery is fully charged. Tried everything above with half choke and no choke. Still nothing.
The only thing i haven't gotten into is timing with a light, timing on vacuum and a compression test. Because i don't have the tools and can't get it to run. | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | If he does not chime in send a PM to Hotrod Lincoln. Jerry help me through a similar problem but it has been 10 years or so. He had me run a wire from the starter but I don't remember to where.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | 2 gauge is much less copper than 2/0 cable. You want cables nearly 5/8” diameter outside the insulation.
I still suspect low voltage at the coil while cranking. Measure voltage at coil hot terminal to ground while cranking. Or use a separate battery to supply power to just the coil for testing purposes and see if it runs. You can even use a 12v battery for this test. Remove wire feeding coil from ignition switch at the coil end and connect your 12v battery to coil and a ground.
Each engine is different but I wouldn’t choke for more than a moment at a time. You may have flooded it right of the bat. To reverse that crank with foot to the floor, no choke. Or wait.
| | | | | Joined: Mar 2010 Posts: 10,271 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,271 | You need to see if you have spark at a spark plug. Pull one plug, attach the spark plug wire to it and have a recent acquaintance hold it to bare metal while you crank the engine over. Don't have a friend hold the plug to the ground just in case he carelessly shocks himself and instantly becomes a former friend. Carl
| | | | | Joined: Aug 2001 Posts: 3,588 Moderator | | Moderator Joined: Aug 2001 Posts: 3,588 | My Dad did that to me when I was really young! He would shut off a running lawn mower by shorting the plug to the frame with his hand. To this day, I can't stand to be shocked.
Don Edit: He also tole me when he was a teenager back in the 30's. The boys would see who could kill a running four cylinder Model T by shorting out the plugs with their fingers. No wires removed, Just ground the plugs out with your fingers.
1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Jun 2019 Posts: 22 'Bolter | | 'Bolter Joined: Jun 2019 Posts: 22 | Grigg/We B Old you guys got me a lot closer than I've been in weeks. I ran a 12g wire from the positive battery terminal directly to the coil. Turned it over and it started belching and farting. WAY more response than I've gotten since i last drove it. So from that I'm taking that the new battery cables i installed are too thin and my timing is now off from me fiddling with it.
I got a buddy who builds hotrods that says he's got 6 feet of cable in his garage. So hopefully I can get it back on the road by this weekend. | | | | | Joined: Aug 2004 Posts: 1,417 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,417 |
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Jun 2019 Posts: 22 'Bolter | | 'Bolter Joined: Jun 2019 Posts: 22 | Churchton It's between Shady Side and Deale 20 min south of Annapolis and Edgewater
| | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | Sounds like the ”Engine whisperer” is now on the case. If it can be started, it will come alive!
Chris | | | | | Joined: Jun 2008 Posts: 48 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 48 | I would check the condition of the points. The "No Fire" makes me think that the distributor is not grounding the coil. Inspect the condition of the contact on the points. I would just file them and set the gap and then see if I could get the engine to fire. | | | | | Joined: Jun 2019 Posts: 22 'Bolter | | 'Bolter Joined: Jun 2019 Posts: 22 | I swapped out the points and condenser. Then I had no spark. Put the old ones back in. Now I have spark. What gives
I need to find someone local who can come in here and start this darn thing. I'm missing out on the whole summer | | | | | Joined: Mar 2010 Posts: 10,271 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,271 | Clean the brand new points. They often come with some type of crap on the contacts. Another cause could be the wire between the coil and the distributor. The copper inside the wire can fatigue over time from the frequent movement of the distributor via the vacuum advance.
| | | | | Joined: Jun 2019 Posts: 22 'Bolter | | 'Bolter Joined: Jun 2019 Posts: 22 | Thanks I'll check. But I'm getting good spark now but it's not kicking over. I'm getting to be at my wit's end
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Fuel, fire, compression each at the right time. You say you have the fire. You’ve poured fuel down the carburetor, so you have fuel. That leaves compression and timing to check.
| | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | When I doubt, take a beer break so you don't get frustrated with it. | | | | | Joined: Jun 2019 Posts: 22 'Bolter | | 'Bolter Joined: Jun 2019 Posts: 22 | That's the problem. Too many beer breaks. Not enough figuring out
I'm too green to get this on my own | | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | I wish I was closer to assist you.
Chris | | | | | Joined: Jun 2019 Posts: 22 'Bolter | | 'Bolter Joined: Jun 2019 Posts: 22 | Thanks. The thought is appreciated. You know who's not coming over to help? My brother the mechanic who's 45 minutes away. | | | | | Joined: Mar 2010 Posts: 10,271 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,271 | Thanks. The thought is appreciated. You know who's not coming over to help? My brother the mechanic who's 45 minutes away. Invite your brother over for a bachelor party for an imaginary friend. Once your brother shows up, just tell him that the wedding got called off. Carl
| | | | | Joined: Jun 2019 Posts: 22 'Bolter | | 'Bolter Joined: Jun 2019 Posts: 22 | So, it runs. I advanced the octane setting all the counter clockwise. After turning it over for about 3 minutes i heard it cough. Gave it a break and tried again. It coughed twice. Another couple breaks and a bunch of coughing and my truck came to life. Ran it for about a half hour and let it come up to temp and shut it down. an hour later after it had cooled it started right up. drove it around a bit, ran a few errands and it continued to start right up.
Thanks everyone for all your help on this.
Here is a summary of my work. Truck was flooding
-Rebuilt the carb. Then it wouldn't start -Changed out the battery cable to 2 gauge cables (too small) -Rebuilt the starter -Changed the battery cables to 2/0 gauge along with new connectors. Everything soldered and crimped -Bought and installed a new starter from Napa -Changed spark plugs and points setting them to manufacturer's specs -Fiddled with the timing and octane setting -Truck started
Thanks again guys. See you out on the road | | |
