6 members (NJC, 55shaker, Joe H, DannyW, 2-Ton, Gdads51), 66 guests, and 1 robot.
Topics128,090
Posts1,056,022
Members48,430
#1316416 07/03/2019 8:02 PM
Y
Olddog
Olddog
Y Offline
[Hello again, Yankabilly with a question? I am at the moment thinking of putting a 305 in my 1948 GMC 1/2 Ton pickup. Question is will my 4 speed, ( was mounted to the original 228 engine) mount up to a 305 engine? And would I need to replace the Bell Housing? Again thank you for any, and all help! [email protected].
Are you asking about the GMC 305 V6 or the Chevrolet 305 V8??? The experts will need to know...
Also, this is a public forum and you really shouldn't post you email address in the open like that...use the "PM" feature to share that info. You can go back and "edit" your original post to remove it.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Y
Olddog
Olddog
Y Offline
Thank you good advice, 305 V8.
Mike F.
I have seen it done. You will need a V8 bellhousing which accepts the Saginaw transmission pattern of your original transmission and you may have to do some modifying to make the clutch work (out of my realm of knowledge). You will need exhaust manifolds from a 265 V8 in order to clear the manual steering box. I hope that your frame is in perfect condition. A 305 with 4.11 rear end gears will put a serious amount of twist on the frame when you stomp on the gas pedal.
Carl
