1 members (VicZ),
231
Mod | | | Forums66 Topics128,087 Posts1,055,976 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2018 Posts: 30 Olddog | | Olddog Joined: Oct 2018 Posts: 30 | [Hello again, Yankabilly with a question? I am at the moment thinking of putting a 305 in my 1948 GMC 1/2 Ton pickup. Question is will my 4 speed, ( was mounted to the original 228 engine) mount up to a 305 engine? And would I need to replace the Bell Housing? Again thank you for any, and all help! [email protected]. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Are you asking about the GMC 305 V6 or the Chevrolet 305 V8??? The experts will need to know... Also, this is a public forum and you really shouldn't post you email address in the open like that...use the "PM" feature to share that info. You can go back and "edit" your original post to remove it. Mike B  | | | | | Joined: Oct 2018 Posts: 30 Olddog | | Olddog Joined: Oct 2018 Posts: 30 | Thank you good advice, 305 V8. Mike F. | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | I have seen it done. You will need a V8 bellhousing which accepts the Saginaw transmission pattern of your original transmission and you may have to do some modifying to make the clutch work (out of my realm of knowledge). You will need exhaust manifolds from a 265 V8 in order to clear the manual steering box. I hope that your frame is in perfect condition. A 305 with 4.11 rear end gears will put a serious amount of twist on the frame when you stomp on the gas pedal. Carl
