1 members (Harmon Hodge),
113
Mod | | | Forums66 Topics128,129 Posts1,056,700 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2018 Posts: 760 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 760 | I just read the tech tips for rebuilding door hinges. In there, it says that they used a bit that was one thousandth larger than the pin. Is this correct? I plan to order a good bit, just for this job, and I want to be sure to order one that will give me the proper clearance. In your experience, how much clearance should there be for these hinge pins. My truck is a 53 half ton.
Mike Burns 1940 Chev 1/2 ton 1953 Chev 1/2 ton 1950 Studebaker Starlight Coupe 1947 Indian Chief 1943 Indian 741
| | | | | Joined: Jul 2000 Posts: 2,198 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,198 | Been a while, but if I remember correctly, the hinge pin kit I bought came with bushings. You drill using the appropriate size for the bushing. The pin fits the bushing very closely.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Feb 2004 Posts: 29,838 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,838 | Use a chucking reamer with lots of lubricant in a drill press instead of a drill bit- - - -drills don't cut accurate holes! Victor Machinery company has chucking reamers available in .001" size graduations for reasonable prices. www.victornet.comJerry
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | The two Tips are excellent. Follow them both. This is not a super precision effort. The .001 is an error. The difference between an S bit and a 11/32 bit is .0043. Get the repair kit first. Then measure pieces with calipers. Then try to use a standard bit. Then decide what to buy. You just need a light press fit of the bushing into the hinge. The fit of the pin and bushing is given. You can't decide ahead of time what drills to buy. Take your time. You can chuck a pin in a drill press and sand with emery if it's a little too big. Provided there is extra length to fit in chuck. You can possibly use a bolt, washers and nut to "press in" the new bushings.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2010 Posts: 10,296 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,296 | The hinge pin kits should include instructions for what size drill bit to use. Do yourself a favor and spring for a high dollar new drill bit to get an accurate hole. I have rebuilt many AD hinges for myself and others, and have never had one requiring use of the bushings. The bushings are for Task Force trucks and AD trucks with horrendously worn hinges. Carl
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Check the tech tip section for some pointers but wait till you get the pins before drillings. | | | | | Joined: Aug 2018 Posts: 760 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 760 | Hinges are rebuilt. Lots of good info provided by you guys. I used 11/32" to drill the hinge bars, and a size "R" on the brackets. Everything is nice and snug, but still operates smoothly. This is Deve's method.
| | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | invest in calipers. only way to know what you are drilling with, and drilling for....thousandths matter! | | |
