3 members (IHPWR, Phak1, TPR57C), 73 guests, and 1 robot.
Topics128,157
Posts1,056,877
Members48,458
Stovebolt members,
I would like to see some suggestions for placing radio speakers in my restored 1958 Apache. The dash is finished. There was never a hole or slits in the dash, so a speaker in the dash is not an option. Not crazy about putting a single speaker above the rear view mirror. Also, not going to cut up the kick panels and install speakers.
Therefore, I am asking for ideas and would like to see some pictures of where you have installed speakers in your truck.
Thanks all,
From an Internet search: "The original speaker was in a metal box just above the windshield."
Maybe someone can show what the original speaker looks/looked like?
None of these suggestions will suit your request.
- You have probably seen these kick panels? (if you want stereo)
- KIck panels with speakers.
Here are some ideas/suggestions.
Good morning Tim,
Thanks for the input. I have seen these kick panels, but decided not to go that route. Going to visit an auto stereo business this week and discuss the situation with them. Considering a speaker box (small) placed behind the seat on both sides of the cab or under the dash on both sides of the cab. Might be an experiment in progress.
Hello, John,
Your ideas look/sound good. Let us know know what you do, and please post a few photos.
By the way, it would be nice to meet each other - if you ever see a show/meet between us, please let me know (maybe in Greenville, Wilson, Rocky Mount, Goldsboro?).
Tim,
Sure thing. Thank you. I always appreciate your input that you provide.
this is what it looks/looked like. of course back in the day it was a single speaker. in the aftermarket you can now get a pair of small speakers that fit in the same housing. they don't sound very good however...
They don't sound bad IF you have a pair of 6x9's behind the seat and balance the bass and treble...that's what I have in my '56 3100.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Speaker boxes set at a 45 degree angle in the cab corners on either side of the rear window work pretty well. I've made them from sheet metal or plywood at various times. Cover them with upholstery material that matches the seat.
Moderator, Electrical Bay
You can also put a couple under the dash...level with the bottom of the dash actually and pointing down at the floor. Then you can put two more behind the seat near the floor pointing upward.
~ Jon
Would appreciate it if any of you, (John G, Hotrod Lincoln or Mike B) would post a picture of what your speaker installs look like. I'm pretty annal about installing these speakers.
Thanks guys,
if the truck doesn't already have the hole in the roof for the original speaker, i would not recommend cutting it up to install the poor quality original-look speaker. a pair of 3" speakers can't really be made to sound good, especially for bass. My replacement cab came with the hole so I was forced to put a speaker there.
tclederman and tomctomc,
Gentlemen,
I have not found anything yet, but churning over some ideas. No, my truck has no factory provisions for radio speakers although the dash was pre-formed for a radio to fit in there, just no provision for a speaker(s). We will not be cutting any new holes anywhere. Don't believe putting anything behind the seat is an option as the gas tank is there. Also don't want to 'hang' speakers in the cab corners behind the seat. Looking like the best option is to mount them under the dash and hope for the best.
My 58 Apache 32 came to me with the single speaker mounted to the bottom edge of the dash, just below the radio.
If you changed your mind and removed it, I don't believe there'd be any noticeable remnants at that location.
Art
Hi Art,
Glad to meet you and thanks for your input. I am seriously considering installing two speakers under the dash and hopefully so they are not to visible. That looks to be my only option without cutting holes in something and I don't want to do that.
one more thing i want to add: unless you used a lot of Dynamat (or equivalent) in the cab - driving a task force pickup is like sitting in a big metal drum. add in the stovebolt 6 thrashing away - ya can't hear music anyway when driving down the road! So - in my opinion - put your speakers wherever they'll fit w/o doing irreversible damage to your cab
Your Task Force truck’s must be much noisier than my 1954 Suburban (restored with standard insulation and standard radio speaker)?
I hope my 1954 Pickup will not be as loud as you describe.
Here's a video of my sound with the speaker mounted above windshield.
Radio sound
I used a RV outdoor speaker because it was the only speaker I could find that was shallow enough to fit inside the speaker box. I have an extra one if you are interested?
Here's a picture of my factory speaker box too.
~~ Darcy
1959 GMC 9310 Canadian- built Shortbox Fleetside Deluxe
FootStomper
In the Project Journals Forum
John e/mailed you a couple of pictures of how I did mine.
Brian
1955.2 3100 Truck
I'm pretty happy with 6X9's fastened to a 1/2" plywood face that has a new shop towel painted black over the hole and mounted low as possible in each cab corner behind the seat. Two 4" speakers under the dash at each corner finish the low tech/low cost system. Sounds acceptable and for all practical purposes it's out of sight.
RonR
1970 340 Duster
1964 CJ5
Socket Breaker
Socket Breaker
I've seen some deals where people build a panel that go around the vent opening, put speakers down there, next to the vent opening... using fiberboard, fiberglass... the cover with interior matching material.
-Woog
The PO cut holes in the doors of my truck. I said to myself shortly after buying the truck "Next project is to put new interior panels on the doors" That was probably 25 years ago. Still have the replacement panels in my shop. Maybe I should sell them. Decided later to just use them holes with new speakers. Love the music.
Craig
