5 members (MickeyP, dt235sd, Wally / Montana, JW51, Bill Hanlon), 58 guests, and 2 robots.
Topics128,049
Posts1,055,699
#1313785 06/09/2019 11:45 PM
7
7 Offline
I got some help from my sister to show everyone what I've been working on. Up to this point I have not been able to figure out how to post pictures. This is from Thanksgiving day 2018 when we loaded 92 bales of hay on her.
78buckshot #1313788 06/10/2019 12:01 AM
Nice!!
Mac :{)
1962 K10 short step side, much modified for rally
1969 T50 fire truck, almost nos, needs a few things
78buckshot #1313809 06/10/2019 2:48 AM
Looks good! thumbs_up
Loaded right to the max...any more and the tires would be rubbing the bed!
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
78buckshot #1313819 06/10/2019 4:12 AM
Looking good! I like it!!
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
78buckshot #1313829 06/10/2019 11:21 AM
7
7 Offline
Mike B, I think the bed has settled a little from the 60+ year old wood "joists" deteriorating, it's a 16000 lb. GVWR with a 15000 lb. axle, that load didn't even touch the overload springs.
78buckshot #1314050 06/12/2019 4:00 AM
Big Bolt Forum Moderator
good looking truck!!
Mike
78buckshot #1314076 06/12/2019 12:22 PM
Crusing in the Passing Lane
Nice truck, what engine and transmission?
Ed
78buckshot #1314077 06/12/2019 12:26 PM
TGP Offline
Nice.
Those LCF's are few and far between
With V8 power that truck would be really sweet with a 2speed rear.
Tom
78buckshot #1314133 06/12/2019 11:59 PM
7
7 Offline
The 283 and SM420 are original as is the rear end, I don't know if it's 6.17:1 or the 7.20 but the engine doesn't need a 2 speed rear - plenty of grunt with this set-up, top speed against the governor = 45mph
78buckshot #1314136 06/13/2019 12:04 AM
I love the front end on that truck! To me that's classy
78buckshot #1314137 06/13/2019 12:14 AM
7
7 Offline
It makes me smile every time I walk into the barn and see it waitin' for me. Like TGP said, few and far between.
78buckshot #1314166 06/13/2019 4:05 AM
Your truck would have had the 15,000 pound corporate rear with 7.20 gears as standard equipment and the 45 mph speed would pretty much confirm that's what you have. The 6.17 would give you speeds close to 60 mph.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
78buckshot #1314180 06/13/2019 9:37 AM
7
7 Offline
Thanks Mike, when I had the diff. cover off I forgot to look for teeth numbers but I was leaning towards the 7.20 from what I was reading on the GM Heritage specs, I appreciate the confirmation.
78buckshot #1314228 06/13/2019 10:04 PM
7
7 Offline
Hey Pvmt-Pndr, we're next door neighbors, I'm in Washtenaw county but I don't think we could be any further distance apart in our counties. I'm in the far northwest township and you're in the far southeast, we could try to meet some time.
78buckshot #1314325 06/14/2019 5:50 PM
Nice! It'll be awhile until mine is road worthy but once it is you're bound to see me hauling the wife's bright orange mud truck down the road!
78buckshot #1314374 06/15/2019 1:26 AM
7
7 Offline
Mine is pretty road-worthy but I would hate to have to make a long trip with it, she's wound out against the governor at 45 mph, I haven't put a tach on it but the specs say GM didn't want it over 4000 RPM, it sounds pretty close to that. I'm guessing we are about 60 miles from each other, it would be a rough trip for the 5700.
78buckshot #1314377 06/15/2019 1:31 AM
I'm against the governor at 59 currently and that's going down hill and she's singing away drinking gas and not getting anywhere fast. Once I pin down what gear to go with I'll be able to do over 70
78buckshot #1314399 06/15/2019 10:29 AM
7
7 Offline
My old girl was never designed for much over 60mph and I wouldn't want to get close to 70 but your rig is 'modern' and should handle it ok.
78buckshot #1314447 06/15/2019 11:34 PM
"Modern" haha. I don't see myself doing 70 most days but having the option should be nice. It's amazing how similar a newer truck is setup to mine, not much of a difference really.
78buckshot #1314491 06/16/2019 12:31 PM
7
7 Offline
That's why I called your truck "modern".
78buckshot #1314543 06/16/2019 9:16 PM
Very nice LCF.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
78buckshot #1314560 06/17/2019 12:49 AM
7
7 Offline
Thanks Spanky and all others for the thumbs-up, as you can see I haven't done anything to the body except lighting and mirrors. I've put in lots of hours on the drive train and brakes so most of the money and time don't show but I know everyone here can appreciate it. I don't know how far I will go with restoration but I'm having a good time with it regardless.
78buckshot #1314626 06/17/2019 3:12 PM
As far as I'm concerned you've put the money where it needs to go. No sense in having something shiny that you can't use because of a mechanical problem.
