0 members (),
129
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2019 Posts: 4 New Guy | | New Guy Joined: Mar 2019 Posts: 4 | Doing the front cross member now & need to do the rear next. My question is what would be a decent axle for a 1954 Chevy 3100? It will be mated up to a 454 & a T10 4 speed. I will be getting a 4 link as well. Thank You... | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Any later rear axle with 6 lug bolt pattern, and desirable ratio.
Ed
| | | | | Joined: May 2009 Posts: 85 'Bolter | | 'Bolter Joined: May 2009 Posts: 85 | I will be using an axle from I believe a 76 or 77 blazer. seems to be about the right width which is all that matters cause you'll be changing all the mounts any how. I have all the parts, just no time.
1949 3100
| | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | With the torque that powertrain setup will have available, the obvious choice is a 9" Ford axle- - - -the same basic gearset the NASCAR guys use. Try one from a 1970's Econoline 150 van for approximately the right tread width. There's a trainload of specialty parts and pieces for that axle- - - -limited slip carriers, disc brakes, etc. and any gear ratio you can dream up, also. Jerry
| | | | | Joined: May 2009 Posts: 85 'Bolter | | 'Bolter Joined: May 2009 Posts: 85 | With the torque that powertrain setup will have available, the obvious choice is an 8" Ford axle- - - -the same basic gearset the NASCAR guys use. Try one from a 1970's Econoline 150 van for approximately the right tread width. There's a trainload of specialty parts and pieces for that axle- - - -limited slip carriers, disc brakes, etc. and any gear ratio you can dream up, also. Jerry Agreed, went back and reread post and see Jupiter did not note 6 lug, the mention of 6 lugs was the next post. I chose the blazer axle to keep 6 lugs.
1949 3100
| | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | OOPS! I just realized I fat-fingered a key there- - - - -should have typed 9", not 8"! Here's a few ideas about building a custom-fit rear axle capable of handling a beaned-up big block Chevy: https://www.quickperformance.com/Ford-9-Inch-9-Ford_c_37.htmlJerry
