0 members (), 151 guests, and 1 robot.
Topics128,115
Posts1,056,289
Members48,439
#1312686 05/31/2019 7:28 PM
Doing the front cross member now & need to do the rear next. My question is what would be a decent axle for a 1954 Chevy 3100? It will be mated up to a 454 & a T10 4 speed. I will be getting a 4 link as well. Thank You...
Jupiter #1313670 06/08/2019 11:20 PM
Crusing in the Passing Lane
Any later rear axle with 6 lug bolt pattern, and desirable ratio.
Ed
Jupiter #1314036 06/12/2019 2:42 AM
I will be using an axle from I believe a 76 or 77 blazer. seems to be about the right width which is all that matters cause you'll be changing all the mounts any how. I have all the parts, just no time.
1949 3100
Jupiter #1314039 06/12/2019 2:53 AM
H Online: Content
With the torque that powertrain setup will have available, the obvious choice is a 9" Ford axle- - - -the same basic gearset the NASCAR guys use. Try one from a 1970's Econoline 150 van for approximately the right tread width. There's a trainload of specialty parts and pieces for that axle- - - -limited slip carriers, disc brakes, etc. and any gear ratio you can dream up, also.
With the torque that powertrain setup will have available, the obvious choice is an 8" Ford axle- - - -the same basic gearset the NASCAR guys use. Try one from a 1970's Econoline 150 van for approximately the right tread width. There's a trainload of specialty parts and pieces for that axle- - - -limited slip carriers, disc brakes, etc. and any gear ratio you can dream up, also.
Agreed, went back and reread post and see Jupiter did not note 6 lug, the mention of 6 lugs was the next post. I chose the blazer axle to keep 6 lugs.
1949 3100
Jupiter #1314052 06/12/2019 4:15 AM
H Online: Content
OOPS! I just realized I fat-fingered a key there- - - - -should have typed 9", not 8"! Here's a few ideas about building a custom-fit rear axle capable of handling a beaned-up big block Chevy:
https://www.quickperformance.com/Ford-9-Inch-9-Ford_c_37.html
