| | | Forums66 Topics128,035 Posts1,055,559 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2001 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2001 Posts: 47 | I have an opportunity to buy a rebuilt 1972 472 cad engine and transmisson and have a nova rear end in the shed. Anyone have experience with this transplant in a 1950 1 /2 ton pickup? | | | | | Joined: Dec 2003 Posts: 510 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 510 | I don't know anything about the Caddy motor, although I'd venture to guess the tranny is a TH400 which should be plenty strong enough for most applications. The rear end...well, let's just say that there were several types of rear ends used in Novas. they range from 8.2 inch 4-lug setups in 62-63, 8.2 5-lug, 10-bolt used thru 72 or so 8.5 inch 10 bolts used in 66-79 applications and a smattering of 12-bolt units here and there. So by saying a "Nova rear end" you've essentially said, "I have a rear end that may have come out of some GM car." I'd suggest finding out a whole lot more about it here: NovaResource.com before going a whole lot further. | | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | i have a 500 cad in my 64. | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | :confused: There is one thing that I know about Cadillac engines. I believe the oil pan is reverse of the Chevrolet, that is, the deep part of the pan ends up right over the axle, instead behind it. That gives some folks problems. Might want to check it out.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | I am no pro,but I would get a Chevy smallbolck for that pickup.They are easy to find,and usually priced reasonable.Plus parts are ready available.Just my 2 cents worth. Dale | | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | eldorados have the oil sump in the back. | | | | | Joined: Apr 2004 Posts: 543 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 543 | I've come across a wrecked but complete '71 Coupe deVille with a 500" engine and TH400 tranny. I'm looking to put this in my son's '46 Chevy 1/2 ton. The Caddy engine, BTW, is only 10 pounds heavier that a SBC, 100" bigger than the biggest SBC built, and gets a heckuva lot more attention at a cruise or a show!. I've even thought about a 440 Chrysler with a Six-Pac (Tri-Power for those solely of GM upbringing!), as I have three 440 engines along with a Six-Pac set-up that's about 75% complete. People don't hesitate to put a SBC in just about everything; I think it's time the tables were turned! :p
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass. Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I like the Cadillac better than the Chrysler!
If I'd found a 500 Cad before I found a 454 the 500 would be going in mine.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
