4 members (55shaker, IHPWR, Otto Skorzeny, 1 invisible), 76 guests, and 2 robots.
Topics128,026
Posts1,055,403
Members48,422
#131298 05/12/2004 3:01 PM
I have an opportunity to buy a rebuilt 1972 472 cad engine and transmisson and have a nova rear end in the shed. Anyone have experience with this transplant in a 1950 1 /2 ton pickup?
#131299 05/12/2004 4:37 PM
I don't know anything about the Caddy motor, although I'd venture to guess the tranny is a TH400 which should be plenty strong enough for most applications.
The rear end...well, let's just say that there were several types of rear ends used in Novas. they range from 8.2 inch 4-lug setups in 62-63, 8.2 5-lug, 10-bolt used thru 72 or so 8.5 inch 10 bolts used in 66-79 applications and a smattering of 12-bolt units here and there.
So by saying a "Nova rear end" you've essentially said, "I have a rear end that may have come out of some GM car." I'd suggest finding out a whole lot more about it here:
NovaResource.com before going a whole lot further.
#131300 05/13/2004 12:41 AM
Z
Z Offline
i have a 500 cad in my 64.
#131301 05/13/2004 3:42 AM
:confused:
There is one thing that I know about Cadillac engines. I believe the oil pan is reverse of the Chevrolet, that is, the deep part of the pan ends up right over the axle, instead behind it. That gives some folks problems. Might want to check it out.
#131302 06/01/2004 11:06 PM
I am no pro,but I would get a Chevy smallbolck for that pickup.They are easy to find,and usually priced reasonable.Plus parts are ready available.Just my 2 cents worth. Dale
#131303 06/02/2004 2:23 AM
Z
Z Offline
eldorados have the oil sump in the back.
#131304 06/06/2004 4:05 PM
I've come across a wrecked but complete '71 Coupe deVille with a 500" engine and TH400 tranny. I'm looking to put this in my son's '46 Chevy 1/2 ton. The Caddy engine, BTW, is only 10 pounds heavier that a SBC, 100" bigger than the biggest SBC built, and gets a heckuva lot more attention at a cruise or a show!. I've even thought about a 440 Chrysler with a Six-Pac (Tri-Power for those solely of GM upbringing!), as I have three 440 engines along with a Six-Pac set-up that's about 75% complete. People don't hesitate to put a SBC in just about everything; I think it's time the tables were turned! :p
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass.
Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
#131305 06/07/2004 4:58 AM
I like the Cadillac better than the Chrysler!
If I'd found a 500 Cad before I found a 454 the 500 would be going in mine.
