| | | Forums66 Topics128,129 Posts1,056,697 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2001 Posts: 17 Member | | Member Joined: Aug 2001 Posts: 17 | What is a good way to get an affordable weld in IFS? I was thinking of getting the M2 crossmember separate, and going to the parts store for the rest. Is this good or should I buy a kit? What would it cost to piece out vs buying a $2000-2500 kit? Any sugestions are appreciated. Thanks!  | | | | | Joined: Jul 2001 Posts: 149 Member | | Member Joined: Jul 2001 Posts: 149 | Buy the kit! Its the best way. To much trouble messing with matching up parts to fit. Vs. a kit were all the parts were built to fit together
"Finish the thing, do it right the first time, and drive the S.O.B.!"
1949 Chevy half ton 3100 In a kazillion pieces 2000 GMC Serria 1500 SL 4x4
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Bigbinaz, probably depends on teh type truck you have. Mine is 37 pickup with original chassis. I welded a plate to the inside of chassis from about the cab to front.Then had a local streetrodder weld my crossmember under it and welded the coil spring towers in place with the brackets to attach the A-arms etc. Next i went to the junk yard and for 75 bucks took the front end out from under a 78 mustang II. blasted and cleaned them up, put in new joints and bushings, 85 bucks for chev bolt pattern rotors but still used the stang II calipers. Bolted in the 350/350 with malibu rearend and it drives real good. total cost in the front end,$800 including the fabrication/labor. One thing important was when we welded the rear cross member and the motor mounts we had a "dummy" block and tranny shell to make sure everything fit just right. you can see my truck here at the stovebolt gallery. look under the 36-40 year and under Alvin's...if you have lots of money...go kit...if in no hurry and want to do it all yourself then this is a possiblity....I spent 5 1/2 years on mine  | | |
