Brrrr
place holder
4 members (1955 1 Series, Wheelie, Hotrod Lincoln, 52Carl), 108 guests, and 3 robots.
Topics128,271
Posts1,058,417
Members48,485
I have more zippers then a pair of cargo pants
Does anyone know what specs (the max they can be turned) for the brake drums for a 1951 Chevy 1 Ton Panel? ... thanks...joe
~ Joe
Donate Blood, Plasma, Platelets and Sign Your DONORS CARD. The Life You SAVE Might Be Someone You Know and LOVE.
Two possibilities exist: Either we are alone in the Universe or we are not. Both are equally terrifying. ~ Arthur C. Clarke
3B Offline
Hy TooMany2count. without actually looking up the specifications I would say .060", hope that helps.
Thanks, but I need the total inside diameter so I when I use a brake drum gauge,I know if the drums are good or not....joe
~ Joe
3B Offline
Hy again TooMany2count, according to my truck salesman's data book your truck should have 12" front brakes and 14" rear brakes, the maximum diameter on your gauge for the front brakes would be 12.060 and the maximum diameter on your gauge for the rear brakes should be 14.060. The rear brakes may be able to be turned out to 14.090 but I will keep looking for the specification to be sure, hope that helps.
Thanks & yes that helps a lot, it'll give me some idea if they are worth saving or if they become scrap....joe
~ Joe
I have found very little mention of this limit in the shop manuals. The Chev manual mentions turning the drum out to 60 and installing the stock oversize shoes. There is mention in one of the GMC manuals of .125" as the limit. I would guess that most shops would automatically say .060". By the way you can't buy these drums new and they are very hard to find used or NOS .
1951 1 Ton Completed
Tim thanks for the info & the link....joe
~ Joe
Joe, Eli and I are working on his truck. Should have a spare set of rears coming up this summer. No idea if they are turnable or not but can check my friendly neighborhood mechanic once we get them off.
Just here for the free beer.
1953 1-Ton Dump Truck
1954 Teenage Hot Rod
