11 members (Gdads51, dt235sd, Gray_Ghost, Woodcmiami, Shaffer's1950, Nick in Manitou, Jon G, Otto Skorzeny, Hotrod Lincoln, walter74, 1 invisible), 70 guests, and 4 robots.
Topics128,131
Posts1,056,372
Members48,441
#131172 12/09/2002 3:16 AM
Junior Member
Junior Member
I don't know much about NOS but has anyone (or is it even possible?) to hook up NOS to a stock 235? eek If not how much modifications would have to be done to do it? I'm probably not going to to his hook up but just curious about it. Thanks.
*under construction* 1962 Chev truck: Bagged & bodydropped, shaved, custom made clear tailights & roll pan, custom made aluminum parts.
http://www.geocities.com/philswebsite2003/
#131173 12/09/2002 11:51 PM
You could run NOS on a heavily modified 235, with a holley projection, forged pistons, high duration cam, timing retard, etc.
The stock intake, carb, cast pistons and ignition system would prohibit NOS on a stocker. Even a 50 HP shot would make a stock 235 go BOOM.
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#131174 12/10/2002 2:27 AM
Only put a fogger on a stock 235 if your boat is floating away and you need an anchor. Even a 30hp shot will create a lean condition that may be enough to weld the pistons to the block once and for all, if it doesn't send the intake into orbit first. wink
Seriously, if you were to take this thing down to the block and rebuild it with all race technology, I would still say be careful with nitrous oxide. There's a reason you see multiple fuel lines and pressure release valves on racecars.
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
