| | | Forums66 Topics128,159 Posts1,057,037 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 109 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 109 | Hello dose anyone know what the distance should be from the top of the front bed to the rib line under the back window? | | | | | Joined: Jun 2010 Posts: 301 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 301 | What truck in particular?
1949 Chevy 3600 1975 W-25 Hurst Olds 1970 GMC 1/2 ton Fleetside 2010 Chevy Silverado
| | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | E.C. RatRods, you’ve got to tell us what your working on every time you start a new thread. What your asking is not the same on the different styles of trucks. Help us help you.
| | | | | Joined: Nov 2012 Posts: 109 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 109 | Sorry guys was not thinking you don,t know what im working on lol. It is a 1950 chevy 3100
| | | | | Joined: Jan 2002 Posts: 2,843 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,843 | What is a rib line? Top of front bed panel?
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | rib line might be referring to the "belt line" around the cab? | | | | | Joined: Nov 2012 Posts: 109 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 109 | My god did I mess up my first message. Let me start over. I have a 1950 chevy 3100. I am putting the bed on for mark up purpose. I am trying to make sure my bed height is correct by trying to see what the correct distance is from the top of the front bed panel to the belt line under the back window. | | | | | Joined: Mar 2010 Posts: 10,305 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,305 | Are you installing a standard wood bed? The wooden blocks between the frame and the underside of the bed sills dictate the height of the bed.
| | | | | Joined: Nov 2012 Posts: 109 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 109 | | | | | | Joined: Jan 2002 Posts: 2,843 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,843 | rib line might be referring to the "belt line" around the cab? I'm getting 10" from top of front bed panel to bottom of the cab bump or maybe called belt line or maybe called........
| | | | | Joined: Mar 2010 Posts: 10,305 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,305 | Simplest thing to do is to order the bed block kit which comes with correct wooden blocks and rubber pads which will guarantee that the bed ends up at the correct height.
