6 members (rfs56trk, frogfarmer, Bill Hanlon, 50Chevy3100, Buckeye998, JoergK.), 369 guests, and 2 robots.
Topics128,160
Posts1,057,054
Members48,463
#1309598 05/05/2019 2:27 AM
Hello dose anyone know what the distance should be from the top of the front bed to the rib line under the back window?
What truck in particular?
1949 Chevy 3600
1975 W-25 Hurst Olds
1970 GMC 1/2 ton Fleetside
2010 Chevy Silverado
E.C. RatRods, you’ve got to tell us what your working on every time you start a new thread. What your asking is not the same on the different styles of trucks. Help us help you.
Sorry guys was not thinking you don,t know what im working on lol. It is a 1950 chevy 3100
What is a rib line? Top of front bed panel?
Craig
rib line might be referring to the "belt line" around the cab?
My god did I mess up my first message. Let me start over. I have a 1950 chevy 3100. I am putting the bed on for mark up purpose. I am trying to make sure my bed height is correct by trying to see what the correct distance is from the top of the front bed panel to the belt line under the back window.
Are you installing a standard wood bed? The wooden blocks between the frame and the underside of the bed sills dictate the height of the bed.
yes standard wood bed.
I'm getting 10" from top of front bed panel to bottom of the cab bump or maybe called belt line or maybe called........ ohwell
Craig
Simplest thing to do is to order the bed block kit which comes with correct wooden blocks and rubber pads which will guarantee that the bed ends up at the correct height.
