8 members (cmayna, Wally / Montana, Shade Baby, Goach2, Donf, dt235sd, Otto Skorzeny, Joe H), 60 guests, and 0 robots.
Topics128,119
Posts1,056,311
Members48,439
#1308299 04/23/2019 8:58 PM
1 Offline
My husband has a 1930 1.5 ton Chevy in pieces in our barn. Affectionately (well, most of the time anyway) known as "The Money Pit" (and HOW!!!), it has been a work-in-progress for about a year and a half. Because I'm the forum user in the house, it's my task to relay his questions to you good folks. I'm not too knowledgeable about this stuff, so I'll mostly be regurgitating what he tells me without really understanding what I'm typing, so please bear with me. Thanks in advance for your help!
Welcome to the 'bolt. That does sound like a fun project. Please scroll through the various forums and ask the questions that pertain to those particular forums. This way, you will get the best answers.
Another quality post.
Real Trucks Rattle
Welcome to the Stovebolt. interesting project but don't feel bad. I've spent 5-6 years on each project I've had.
We're here to help and don't be afraid to ask questions....just be sure to ask them in the garage forums.
Welcome to the Stovebolt madness. There is no cure! shake
Hi and welcome! At least it ain't a boat- - - - - -"Break Out Another Thousand!" The early 30's rigs are fun, but as you've probably already learned, finding parts can be a challenge. Is he going for a "restoration", or are some newer major assemblies like the engine and transmission be considered? Late 1930's or newer parts can be adapted without a lot modifications.
Watch out for 2-Ton he frequents that neck of the woods .Havebeen with him to the Ozark lake lovely area to be in welcome from keeping the dream alive
Welcome from downunder must remember to proof read
1 Offline
Thanks! We went through our boat phase about 25 years ago. Nothing fancy, just a little Chipmunk sailboat (The sail was way too big for it, so we had the most fun dumping ourselves into the lake), then a little 5-seat Pipestone Princess (I think) with a 50hp Merc outboard. Just enough for us to waterski.
So far, he's doing a frame-off resto, I guess. The frame and some other parts have been powdercoated. He replaced the radiator. New tires, plus some brake work. Our mechanic does metal fabrication on the side and is working on a hood. He had planned to rebuild the engine, but ran into the head being cracked in 13--yes, unlucky THIRTEEN--places. The local engine guru recommended swapping it for a '54-'62 235 so we have the benefits of a more modern engine, but we don't know if it will hook up to the bell housing without modification. I posted my question in the Big Bolt and engine forums. He's a woodworker, so he's most excited about getting to the point of being able to rebuild the bed.
Noticed you had posted the same question in two different forums. That is not acceptable on Stovebolt.com. May I suggest you hop over to the General Truck Talk Forum and read the “Sticky” thread at the top of the page about why things are moved, modified and edited. Lots of good information there about how to use the site.
1 Offline
Oh, sorry. I didn't know whether to put it in the Big Bolt or generic engine section, so that's why I did both.
Moderator
Moderator
2 Offline
Welcome Money Pit!
Ignore that old Kiwi (TPR57C). He is hard to understand.
We are currently on a road trip together and you can read about it here.
https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1305141/1.html
What part of the Ozark are you located?
I live outside of Mokane in central Missouri and get to the Lake of the Ozarks a lot.
See ya around the garage!
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
Big Bolt Forum Moderator
welcome to the site!
Mike
1 Offline
Originally Posted by 2-Ton
Welcome Money Pit!
Don
We're in SW MO, down in twisty country. So while my husband toils away on the Big Bolt, I go have fun riding my motorcycle!! yahoo
