| | | Forums66 Topics128,005 Posts1,055,260 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 46 | I've got a small block 350 in my 59 and the guy I got the truck from told me that it has solid lifters and a hot cam(unknown brand /spec.s)....the motor works good but it's a little noisy. I've done rocker adjustment on the 194 -6 in my '62 Nova(hyd lifters) and if I remember right you just crank down on the rocker stud nuts until excess lash is eliminated. Some sources I've seen say that with solid lifters this needs adjusting more often, do I use the same method (basically by ear) or are the solids just inherently more noisy and I should just get over it?? :confused:
220 - 221 whatever it takes
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Solid lifters are going to make more noise.
You don't adjust solid lifters the same way you do the hydraulics. The proper way requires using a feeler guage to set the gap when the valve is in the closed position.
I've no idea what the specs or exact procedure is for a sbc.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | 59Chief,
My '62 Vette has solids and the procedure is to set them with the engine hot and idling. An old valve cover with the top cut off helps with the oil running onto the exhaust manifolds. Recommended interval is 5,000 miles. The lash on my 327 - 340HP is .008 (hot) on the intake and .018 (hot) on the exhaust.
The sound effects from the solid lifters is definitely part of the experience.
'38 Chevy 1-1/2 ton '49 Chevy 1/2 ton '54 Chevy 6400 2 ton '55.2 GMC 3/4 ton '56 GMC 1-ton
No Room Left in Shop
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | On some engines that solids keep tapping noisely the rocker arm stud could be working out and need to pin them! That is if you continue to have the problem! | | | | | Joined: Sep 2004 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 46 | Thanks OldSub,OlBlue,& A.chipmunk. I was wondering if the lift / duration of the cam would make a diff. on the clearance? Thanks Again, Jeff
| | | | | Joined: Oct 2004 Posts: 15 Junior Member | | Junior Member Joined: Oct 2004 Posts: 15 | Most cam manufacturers specify what the lash should be.... If you don't know what the cam is, I'd suggest checking a few different specs and aim for the middle ground. The exhaust always has more lash than the intake (due to more thermal expansion) | | |
