Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (red450IH, Tronman, oldsteve), 166 guests, and 3 robots.
Topics128,289
Posts1,058,583
Members48,492
Page 164 of 177 1 2 … 162 163 164 165 166 … 176 177
It is sweet. Love that blue.
Professional Novice
Well after 3 years of looking, found myself a 261 to rebuild, it is a complete running engine. Made me a pretty happy camper. Going to go in my 53 1/2 ton.
Steve
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
I got the interior finished
Jeff, don't fall asleep at the wheel while sitting in all that comfort.
~Jim
The glass packs will keep me from doing that and that is the next project.
Completed my wiring on my dash...put in cab tomorrow
1937 GC
Originally Posted by 49 3100
51-3100 How sweet it is...
Wow!
Wow, wow!
1951 Chevy Panel Truck
Got my new t-stat housing installed (thanks to 12bolt/Tom Lowe for a new one), started getting things cleaned up for paint this weekend
Just making an appointment for a tuneup. May put a 180 in instead of the 160.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Replaced a torn wiper blade. Tightened the power steering pulley and added some Loctite. Trimmed back the heat insulation so that it’s all hidden by the carpet. 🛠
Working on installing a Holley 600 on my 250 6 cylinder. Doing a conversion of the carb per Tom at 12bolt.com instructions. It converts it to a 3 barrel; 1 primary and 2 secondaries. I just got a call that the Clifford intake has been blasted and ready to pick up. Now to get the carb back together. Then the fun of figuring out all that need to come together to get it on the truck and working. I'm keeping track the process on my blog; https://myol66.wordpress.com/.
Mike Kelley
1966 Chevy C10 SWB - 250 L6/S10 T5
2002 Chevy Ext 1500 4x4
Http://myol66.wordpress.com
Managed to drill and tap the front bearing block so I can install and remove my timing cover without removing the oil pan
1954 Chevy 3/4-Ton Chevy
"Mo"
1948-53-54 "Mixed Bag" Chevy Stakebed
"Basket Case"
1952 Chevy 3/4-Ton
"as yet un-named"
Lots of pictures
EWW Offline
Planned to address some valve lash on my ‘46. Truck stalled out while warming the motor due to some carb issues. So, I temporarily fixed a carb on the side of the road, limped home, and ordered a rebuild kit.
Spent some time under the hood sealing up all the little and not so little holes in the firewall. Places where screws were removed or where a harness of sorts went through. Around the steering column and the brake booster mount. Trying to cut down on the drafts in the cab around our knees and feet. Chasing gremlins in the turn signal wiring. The connector at the base of the steering column was the culprit. Re-did the wires eliminating the connector and all is well.
Finally had good weather in the U.P. of Michigan today and set my cab on the frame!!! Have a little more room in the shop now and can maybe start working outside on the truck once in a while.
1937 GC
Got my new windshield wiper RainGear installed not a bad deal to install! Now putting in my Vintage Air system inside of cab coming together nicely! There is light at the end of the tunnel!
Pops
Pops the truth is out there!
Been doing a bit of rust management on the ‘62 C-10 this week. Just hitting the surface rust spots with a rattle can spray of primer. Found a can of Safety Blue and did a little coverup on the front facing sheet metal. Hoping to hold the rust mites at bay while I save up for a proper paint job. Off to the “Oklahoma Stovebolt GabFest” in a couple of hours. It’ll be fun meeting some new Bolters and catching up with the familiar faces. Watch for photos in the “Hot Wash Forum”.
drive
Installed my horn bushing in the steering column on my 37. Took all day as I spent half the time thinking about it. Tried to push the bushing in with steering wheel nut but that didn't work out. Finally pulled the entire steering column with gear box and used a threaded rod to push in bushing. Installed steering wheel and new horn button and moved outside column down a little bit to get contact when button was pushed. Glad that job is done.
1937 GC
I got the 235 reassembled this weekend and the crank drilled/tapped for harmonic balancer. Also first coat of paint!
"Mo"
"Basket Case"
1952 Chevy 3/4-Ton
"as yet un-named"
Lots of pictures
I had no post tapped photo- there it is drilled. I used the 12bolt fixture, drill and tap. Went easier than expected.
"Mo"
"Basket Case"
1952 Chevy 3/4-Ton
"as yet un-named"
Lots of pictures
Last coat sprayed tonight. Good enough for a driver. Happy with the results.
"Mo"
"Basket Case"
1952 Chevy 3/4-Ton
"as yet un-named"
Lots of pictures
Nice work Slawnski. Boy, that sure is a bright blue! Looks nice.
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
New distributor, new coil, and a new starter. She runs really well. Time to tackle gauges. My lights and signals and brake light all work, no gauges work, or wipers.
SLAWNSKI,
Looks good! Whats the back story to the color blue you used?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Spare tire back where it belongs, think I need an X-RAY!
1946 1/2-Ton Chevy
Fox Offline
JiMerit,
Do you have a few more pictures of that spare carrier?
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
The Vintage Air system all most done. Spent 2 days while it rained here working on taping off the front emblems to paint! My paint store owner and great friend did a wonderful job matching the orange. Getting ready to order an air brush kit! Danger Wil Roberts Danger!
Pops
Fox, Yes will post a few more pics, it's one of the few items of my '46 that didn't get lost or destroyed.
1946 1/2-Ton Chevy
I've always found a floor jack cheater to be the best help.
~Jim
We’re into the 5th day of having new tile flooring put down throughout 100% of the house. It looks like a tornado came through! Today they tackled the last room..... our master bedroom, and now there’s no place to go! The Mrs. is physically worn out and after I’d washed it she asked if I’d pull the old truck in the shade. She crawled up in the cab and fell fast asleep.
Chuck
1941 Chevy coupe
EWW Offline
Rebuilt a Rochester B that was failing
Cut wood for my bed and installed. was a nice project
Got my toys out and cleaned them up and played with them.
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
Still bleeding brakes ... it's like there's
a gallon of sludge stored in these lines.
Afraid to even touch the master cyl -
( other than topping off fluid )
it's a blob of rust.
1960 C20 Platform
I’d be afraid I would pack more crud into the lines unless you know for sure that won’t happen. Replacing a master cylinder is a bunch raiser than replacing brake lines.
~Jim
Been chasing one electrical gremlin after another since I completed this years section of the Resto-Mod on the ‘62 C-10. I would get the 4 way flashers fixed and move on to a finicky left front turn signal and in the process of fixing that the 4 way would quit. Then the horn quit while at the GabFest last month. Today I was determined to fix all the signal/flasher/horn problems once and for all. Cleaned grounds again and checked the circuit for the turn signal. Had flashing power to the socket but the bulb wouldn’t flash. Worked over the pins on the base of the bulb with a pair of pliers to raise them up a bit thus making better contact. It worked, I now have 4 ways and turn signals on every corner. On to the horn. Bypassed the relay and the aftermarket klaxon horn worked but the factory horn was DOA. None of the FLAPS had a relay so I had O’Reillys bring one over from one of the OKC stores. Installed the new relay, hooked up the klaxon and left the factory horn disconnected. Legal again. Fingers crossed that the repairs will hold this time.🛠
That experience you had reminds me of that old kids game “Twister” with you holding one wire over here and pressing another one with your foot.
~Jim
Martin, a trick I've used on old horns is to turn the tone adjustment screw while someone holds the horn button down. Amazingly enough the two steps have to be done together for results.
The above is assuming all the dirt dabber nest have been removed.
RonR
1970 340 Duster
1964 CJ5
I didn’t have an assistant to help with the horn adjustment. The Klaxon works and the original awaits further testing/adjustments/replacement. We do have a Dirt Dabber problem so I will have to check that. Thanks
Awesome Grandpa
Awesome Grandpa
Sanded / primed ash tray and glove box door. Installed new glove box.
Replaced dome light fixture.
Installed new hood badges.
dome
door
