2 members (Dave1234, 1 invisible), 64 guests, and 2 robots.
Topics128,208
Posts1,057,446
Members48,471
Junior Member
Junior Member
i was thinking on changing IFS on my 66 1/2 ton chevy truck.the only thing is i hear if i do this change the front wheels will stick out 1 inch or so.so if this is correct.then what is the IFS
Measurement on the(67-72).IFS(73-78).IFS(79-84).?85-87 did they all stay the same with in the 5 years i think the 62-66 truck owners who are considering the IFS BOLT ON . need to get a tape mearsure out.and hit the boneyards and see if the IFS "on the years i listed^ are all the same or different.my truck is a short wheel base stepside and i sure don't whant it to look three wheeler turn backwards. if you want to join in finding out the measurements pick a year example >67-72.(73-78).79-84-?-87.i'll measure 79-84 and see what i come up with my buddy has a 84 1/2 ton truck .they should be the same 79-84 ?87.i''l measure and post it as 79-84?87 my brother has a 87 1/2 ton.or if anybody has done IFS swap there self and not here say.let me know how it fit. [/LIST] [/LIST]
Quote
:confused: hopefully you took pictures of the interchange.
Junior Member
Junior Member
i also have factory wheels i don't want to go to other wheels to make the front end look like the IFS is the same as the orginal IFS.i for got to add thatin my meesage.
I just bought a frontend from what is believed to be out of a 73-78. It's for a 66 4wd Suburban. I'll let you know the measurements later today. smile On the phone with guy it sounded like everything was going to be close. grin
Of course you're talkin 2wd and I'm talkin 4wd wink
If at first you don't succeed, get a bigger hammer.
1941 Pontiac business coupe
1947 Chev Coupe
1969 GTO ragtop
i thinkzz traveling along at terminal velocity will soon wear a body out.
i will not die in shame if i never finish my dreams because my family iz my reality
can't wait until we can bed de ponys down, lite de fire, put on a big ol pot of coffee, and talk about how strong and brave our teams are.
bullfoot thinkszzzzzzzzzzz
Z
Z Offline
how are you going to use your six lug wheels on the five lug rotors?
Good point! I'm going to change out the rotors,pads and brake lines anyway, I'll look into the chances of upgrading to 6 lug rotor. If that can't be done I'll take a set of new rotors to my machinist and see what he can do. :rolleyes: Having front disc brakes is worth a small amount of trouble. I saved a bundle upfront on this axle, if I end up spending more it will be spread out over time. grin
1947 Chev Coupe
1969 GTO ragtop
Apprentice
Apprentice
I did the crossmember conversion about 3 years ago on my '66 SWB. I used the entire crossmember from a '73 1/2 ton Suburban. The wheels don't stick out any further now than they did before. Save yourself the trouble of taking a bunch of measurements. The conversion is well worth the effort.
"Praise the Lowered"
'Bolter #29
Well, I was able to see in daylight, the front end that I had aquired. It turned out to be a six lug after all! grin It's not a 73' it's more like an 85'. It looks to measure out the same as my 66' front axle. It certainly is complete enough. Leaf springs and shocks still attached, and the arm that attaches to my pitman arm on my power steering is there. Yeah, I know, don't bother using the shocks, and the rotors need to be turned, and new pads etc. I'm going to install it this weekend I hope. smile
Oh yeah, wink the 66' measured about 60" backing plate to backing plate, and the 85' measured 61" It's hard to get an accurate reading with the front end still under the 66'. Hope this helps some what
1947 Chev Coupe
1969 GTO ragtop
