| | | Forums66 Topics128,095 Posts1,056,480 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2019 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2019 Posts: 53 | So I finally got my truck a couple weeks ago and been tearing into it. Looking at parts from the vendors and used parts people have for sale I’m noticing some differences in parts from my “44” Canadian truck in the aftermarket as well as used parts. One being the door check straps aren’t 2 pieces of flat metal but a piece of round bar another is the exterior door handle design. I know that the middle years are built with existing old stock as my motor number stamped on it matches the tag on the truck and the water pump has a single hole on the back so it is a pre 41 motor and the head is stamped 1940. So what I’m asking is there any info somewhere that lists the differences between the Canada models and the US? Or do you have any info? Mechanical, design, finishes or anything... as stupid as it sounds I’m trying to keep it correct and I know I’m gonna have a harder time finding certain parts.
44 Canadian chevy 1/2 ton
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Bill39568, as far as I know true Canadian trucks did not have metal saving fenders until 1946 if at all, (front fenders that have larger wheel openings and are trimmed towards the grill) hope that helps. | | | | | Joined: Jan 2019 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2019 Posts: 53 | Huh I didn’t notice that. Gonna have to look tomorrow when I go out to the garage.
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | For what it's worth, there were many odd parts on US pickups during war years to save metal etc. Had a couple of those with stamped tin door handles and other with plastic interior handles. Had a military cab that had a huge metal glove box vs cardboard. Best of luck | | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | Did the Canadians ever add chrome trim to distinguish their trucks from US trucks? For cars in the 50s and maybe 60s, Canadians seemed to take pretty, well done US designs and add chrome here and there. The result wasn't so pretty. Not being snarky here but it seemed like the Canadian cars just had to be different. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | So I finally got my truck a couple weeks ago and been tearing into it. Looking at parts from the vendors and used parts people have for sale I’m noticing some differences in parts from my “44” Canadian truck in the aftermarket as well as used parts. One being the door check straps aren’t 2 pieces of flat metal but a piece of round bar another is the exterior door handle design. I know that the middle years are built with existing old stock as my motor number stamped on it matches the tag on the truck and the water pump has a single hole on the back so it is a pre 41 motor and the head is stamped 1940. So what I’m asking is there any info somewhere that lists the differences between the Canada models and the US? Or do you have any info? Mechanical, design, finishes or anything... as stupid as it sounds I’m trying to keep it correct and I know I’m gonna have a harder time finding certain parts. War era trucks from about mid-1942 and later don't have a great deal of rubber parts as that material was scarce due to the Japanese occupying many of the rubber tree regions of the Pacific. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | There was an engine difference too. I believe the Canadian 216s retained the domed piston design until 1946 . That includes of course the old style head. That is reflected in the Canadian and US parts manuals. | | | | | Joined: Jan 2019 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2019 Posts: 53 | War era trucks from about mid-1942 and later don't have a great deal of rubber parts as that material was scarce due to the Japanese occupying many of the rubber tree regions of the Pacific. I did notice those trucks had the leather around the gas filler with the metal trim ring but mine never had that as it doesn't have any holes in the body. As I'm getting further into it I'm noticing it's basically a 1940 truck with the 41 and up body on it.
Last edited by Gdads51; 08/12/2025 12:52 PM. Reason: fix quote and weird characters
| | | | | Joined: Jan 2019 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2019 Posts: 53 | There was an engine difference too. I believe the Canadian 216s retained the domed piston design until 1946 . That includes of course the old style head. That is reflected in the Canadian and US parts manuals. Well I’ll be pulling the motor soon to go thru it so I’ll see! I don’t order or buy any parts for this truck unless I pull apart what I have first to visually figure out what year it matches up with, fun!
