4 members (Swami29, Otto Skorzeny, Gray_Ghost, Youngin' Tut 59), 143 guests, and 1 robot.
Topics128,114
Posts1,056,605
Members48,448
#1307051 04/14/2019 2:32 PM
Hey guys. Can someone point me to a good wiring harness that will allow me to rewire my 54 3100 with a 350 small block? I’ve got a late model chassis and steering column, but the wiring is a mess. I’d rather start over. Having a hard time determining the best harness to go with. .
The most popular is Painless. They are available through all the performance aftermarket parts stores. Pricy but seem to be good quality pieces and instructions are actually written in English.🛠
Sir Searchalot
Sir Searchalot
Not a whole lot of wires that are different on a 350 motor than a 54 motor with basic accessories. Just starting/ignition, sending, charging. 95% is chassis/body wiring.
If I see you are monitoring this I will offer more if you wish. I see you have searched and found info on another post. That's good. I recommend, as far as the Speedway Harness, that you move up to Part no. 91064022.
Yes, Horse Power Products on eBay sells a plug and play harness for your truck. Factory replica, made in USA.
Click here Horse Power Products
~~ Darcy
1959 GMC 9310 Canadian- built Shortbox Fleetside Deluxe
FootStomper
In the Project Journals Forum
Moderated
Moderated
Hi...I have a Kwik Wire 14-circuit outfit in my Ford, I haven't utilized several things like the radio circuit and the third brake light. Trucks are quite essential, take a gander at the Rebel 9+3 saddle. I needed to have heat in my vehicle since I live in NY and it snared to my unique radiator without any problem.
full turnkey assembly
