4 members (Otto Skorzeny, FAST55, Hawkman, 52GMC35424JD), 91 guests, and 1 robot.
Topics128,051
Posts1,055,768
#1305714 04/02/2019 4:54 PM
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Hope you read Carb Kings write up that you have to have at least a 4" distance between carb mount surface and manifold mount surface for a two bbl adapter to get you back to the same readings as the stock factory set up.
Evan
Set, as in two of them? Since it's progressive, the barrels must be aligned across from the head, not along the length of the manifold.
And... what manifold?
WE b OLD #1305746 04/02/2019 10:38 PM
2017 Buick Encore
See more pix
WE b OLD #1305753 04/02/2019 11:45 PM
Your link is broken...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
WE b OLD #1305764 04/03/2019 12:39 AM
2017 Buick Encore
See more pix
Hmmmmmmmmmm
404 thats an error. The set up or the link?
There is not a tool made that if you don't try hard enough you can't break!
1952 3100 261 T5 3.08 Gov Locker
Trying again. Last time.
2017 Buick Encore
See more pix
The link works, my earlier comments w/r/t adapter and alignment apply: the adapter is too short + too small.
WE b OLD #1305862 04/04/2019 12:33 AM
Moderator, Electrical Bay
Hi Ron. Serious opinions are what you asked for...so here is mine: For the first thing with 2 of these you will have about 3 times the CFM rating the 235 needs. Let's go back and look at the equation: Cubic inch (235) x max RPM you expect to be using (let's say 3000...which with your gearing should be a good number) x efficiency factor (let's say .80...for a stock 235 it may be more like .75, however) = 564,000 divided by 3456 = 163. That means 163 CFM ought to be plenty for you. Each of the carburetors you're considering shows to have 240 CFM for a total of 480. 480 divided by 163 = 2.94. 294% too much. This is like filling a stewpot instead of a cereal bowl with your Post Toasties for breakfast. For the second thing, the post by Jon (CarbKing) a few days ago did an excellent job at describing the interference problem you will have with 2 carburetors on an inline six with siamese ports. For the third thing these carburetors were not designed for this engine at all. What I think you need to do is abandon the split exhaust and dual carb setup you have. Go back to a stock exhaust and intake manifold, make absolutely certain the heat flapper in the stock exhaust manifold works as designed, mount it all correctly and then put a properly rebuilt Carter carburetor on there. Make sure whoever rebuilds it pays attention to the fuel inlet orifice size and doesn't use what is being sold out there today. I posted this last summer when I was looking into these...the proper inlet orifice could be .76, it could be .81, depends on the model you have...the ones in the FLAPS type kits are going to be for Ford applications and are too large by 25% or more. Good luck!
~ Jon
Jon, I've been saying the same thing for months- - - - -you're going to be ignored.
WE b OLD #1305914 04/04/2019 10:56 AM
When I read HRL response I sald to my self, self don't respond but here I go again. Jerry, you are a shooter and for the last 10 years, you used your favorite double barrel and it gave you the results you wanted. Then all of a sudden it did not and you mentioned to a friend what happened and he said you need to go to a single barrel. So you said no it served me well for years and I still want to use it the way it was because it was ok for 10 years and there has to be a reason that it has changed. I know I am using more ammo to get the same results but I will keep checking to get it back to the way it was.
2017 Buick Encore
See more pix
