4 members (papas52, Shade Baby, 2 invisible), 91 guests, and 3 robots.
Topics128,087
Posts1,056,340
Members48,442
#1304811 03/27/2019 1:53 AM
I have a pretty solid 250 six that I would like to swap into a 49 3100. I pulled the exhaust manifold and noticed that there is a tube in each exhaust port that is capped with a brass plug in the head. What are these and can I just remove them?
Thanks for your help!
H Online: Content
Those are air injection tubes that the tree huggers who ran the EPA insisted on having for emission control purposes back when that engine was a daily driver. Originally, the engine had an air pump and a rat's nest of tubing connected to those ports. Go ahead and get rid of whatever's sticking into the ports, any way you need to. I'd suggest a Sawzall or something similar.
If the cylinder head happens to have the intake manifold cast integral with it, use that head for a boat anchor and find yourself a pre-smog head with a separate intake to use.
51cowboy #1304848 03/27/2019 12:25 PM
The intake and exhuast manifolds are separate. Thanks for the help Jerry!
