| | | Forums66 Topics128,089 Posts1,056,439 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2014 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: May 2014 Posts: 44 | I have a pretty solid 250 six that I would like to swap into a 49 3100. I pulled the exhaust manifold and noticed that there is a tube in each exhaust port that is capped with a brass plug in the head. What are these and can I just remove them? Thanks for your help!
| | | | | Joined: Feb 2004 Posts: 29,828 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,828 | Those are air injection tubes that the tree huggers who ran the EPA insisted on having for emission control purposes back when that engine was a daily driver. Originally, the engine had an air pump and a rat's nest of tubing connected to those ports. Go ahead and get rid of whatever's sticking into the ports, any way you need to. I'd suggest a Sawzall or something similar.
If the cylinder head happens to have the intake manifold cast integral with it, use that head for a boat anchor and find yourself a pre-smog head with a separate intake to use. Jerry
| | | | | Joined: May 2014 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: May 2014 Posts: 44 | The intake and exhuast manifolds are separate. Thanks for the help Jerry!
