Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 58 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#1304748 03/26/2019 7:12 PM
I've been asked "I have the valve opening & closing points of a cam, but how do I calculate the intake and exhaust centerlines, and the LSA or lobe center angle?"
Using the McGurk #18 data:
For the intake lobe: (intake closing - intake opening) / 2, then add 90 degrees
Example for 10-55 timing: 55 - 10 = 45, divide by 2 = 22.5, add 90 = 112.5 degrees ATDC
For the exhaust lobe: (exhaust opening - exhaust closing) / 2, then add 90 degrees
Example for 72-32 timing: 72 - 32 = 40, divide by 2 = 20, add 90 = 110 degrees BTDC
LSA: (intake CL + exhaust CL) / 2
112.5 + 110 = 222.5 / 2 = 111.25 degrees
I just wrote an Excel spreadsheet that calculates this automatically from your input, e-mail me for a free copy: jdiamond (at) optonline.net
Good school Panic, only thing missing is how to determine cam advance ground into the cam.
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
Use this site, https://www.blocklayer.com/degree-wheeleng.aspx to build your custom degree wheel. Just add the data from the cam card, and you have a degree wheel just for that cam!
Thanks, Joe! Added to my "favorites" list!
BTW- - - -has anybody else thought about drilling and tapping the snout of a stovebolt cam and using a harmonic balancer installer to push the timing gear on?
Typically the suggested (or already selected) intake lobe center is 4 degrees advanced from the CL.
More advance closes up the intake valve-to-piston clearance, more retard closes up the exhaust-valve-to-piston clearance.
Overlap and LSA are constants (at least, in single cam engines!).
