3 members (klhansen, GusG, Otto Skorzeny), 89 guests, and 2 robots.
Topics128,089
Posts1,056,419
Members48,443
#130278 06/07/2003 5:49 AM
Ok...I'm pretty set on going with a mustang II setup. How do I choose between the 100 or so manufacturers of these crossmember kits. This is going to be a piece by piece purchase cause I can't drop 2000 bucks at once. Any help would be greatly appreciated.
Big guy-first off, a hearty welcome to The 'Bolt... smile That said, The biggest recommendation I would make is stick with products from the same manufacturer. Sounds obvious, but you'll be sure to have a pile of stuff that will all work together if you buy all from the same place. Next thing to do is come up with a game plan for your project and stick with it! Do you "just" want a basic MII I.F.S.? Do you want a full-blown adjustable airbag suspension setup? Again, compatibility is the big issue here-in most cases, if you buy an airbag setup, then decide you just want coils or coilovers, you'll be SOL-the stuff won't be compatible, as the airbag crossmember was engineered for use with airbags.
As for different manufacturers, as you say lots out there. We used to have a pro rod builder here who hated Fatman Fabrications and swore by Heidt's Hot Rod Shop stuff. I'm sure you'll get many posts from different folks here who've done this conversion and their thoughts on the different kits available. cool
By the way, what kind of truck do you have?! :confused: That tidbit will be helpful for future postings. wink Best of luck with your project.
Regards,
Wannabe smile
"Don't expect anything and you'll never be disappointed"
Yeah..I guess that little tidbit would be helpful..but it was late. I have a 1950 chevy/gmc truck. I'm planning on using Airride Technologies shockwaves and control arms with whatever crossmember I end up with. Any more tips or suggestions...
Thanks for the hearty welcome!
