1 members (Hotrod Lincoln),
95
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,677 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2019 Posts: 123 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 123 | I started to install a new wiring harness in a 54 chevy pu. One thing led to another and i ended up with everyting out from under the dash. Have painted the interior and am ready to install the under dash components. Does anyone have any suggestions which components to install first and an order to install them. i concerned about installing something the having to remove it to install something else. i dont like to redo things. Thanks for any suggestions.
| | | | | Joined: Dec 2014 Posts: 678 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 678 | Highest stuff first, then work your way down. Don't install your gauges, radio speaker grill or glovebox door until later - you'll need to reach in those front openings for underdash access.
Keep in mind however that I may be the King of having to remove parts to access parts that should have been installed first.
1951 Chevy Panel Truck
| | | | | Joined: Jan 2018 Posts: 298 'Bolter | | 'Bolter Joined: Jan 2018 Posts: 298 | I have my dash on my 37 removed and on the bench. Gauges rebuilt and ready to install wiring harness. Can I wire all the gauges and key and light switch then install dash and let harness hang down until I am ready to put cab back on frame? Thanks for any help. Bill
1937 GC
| | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | I have my dash on my 37 removed and on the bench. Gauges rebuilt and ready to install wiring harness. Can I wire all the gauges and key and light switch then install dash and let harness hang down until I am ready to put cab back on frame? Thanks for any help. Bill I will bet you a dollar AND a donut that the assembly line guys did it that way.
| | | | | Joined: Jan 2018 Posts: 298 'Bolter | | 'Bolter Joined: Jan 2018 Posts: 298 | Thanks for the pep talk 52 Carl!!!
1937 GC
| | | | | Joined: Jan 2019 Posts: 123 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 123 | thanks Shop Shark, i only asked to try not to take your kingship. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ..luckily the 37 only had big screws holding the dash in place!!
On my 52panel I made "pigtails" for my wires so that once stuff was installed I could "plug and play". Worked out nicely. | | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | ..luckily the 37 only had big screws holding the dash in place!!
On my 52panel I made "pigtails" for my wires so that once stuff was installed I could "plug and play". Worked out nicely. I plan on doing the very same thing, with enough slack to let the wires protrude through the front of the dash and make connections and test BEFORE everything is mounted up nice and clean. Then just turn a loop and a small zip tie will make it all look nice and neat. | | | | | Joined: Jun 2020 Posts: 20 'Bolter | | 'Bolter Joined: Jun 2020 Posts: 20 | it didn't madder how I done the wires it still look like a bird help me | | |
