7 members (Donf, Hanks custodian, Cosmo, Gray_Ghost, treegrower, Bill Hanlon, 1 invisible), 105 guests, and 1 robot.
Topics128,080
Posts1,055,956
Members48,430
So, I've managed to get the wing vent assemblies back together, with one exception. I can't find the little rivets that hold the vertical strip in place. I'm talking about the part where the wing vent window closes against the vertical bar.
Does anyone know where to get those? Or what size they are? Or some sort of substitute?
Tim
I am currently digging back in to a 1953 3800 (one ton) with a nine foot bed. I've owned it since 1979, and drove it until 1982 (or so). My wife got me involved in restoring it back in 2002, got the body removed and the frame redone, then things came up. Now I am retired and starting again. If anyone is interested I have photos on Imagur ( https://timwhiteblues.imgur.com/ ). I live way back in the woods in the Ozarks on 40 acres at the end of a 2 1/2 mile private road.
Tim
Sir Searchalot
Sir Searchalot
This may or may not help but seems possible.
https://www.classicparts.com/1951-87-Vent-Assembly-Rivets/productinfo/03-825
https://www.classicparts.com/1951-87-Vent-Rivet-Setting-Tool/productinfo/03-835/
When restoring a truck, one needs to get familiar with vendors who specialize in the parts. Get good at searching those vendor sites. This took less than 12 parsecs to find.
No problem, just FYI. You can thank your Lucky Stars I'm here. Whether you own a "Mercury Comet", a Chevy "Astro" or a Plymouth "Satellite", parts are in this Galaxy. (sorry, I read your profile)
Ha ha, good stuff!
Lots of guys just glue those in place. I would recommend black urethane sealant, and use some clamps to hold the seal in place until the sealant cures.
I just used some small blind rivets. Stainless, so they wouldn't rust.
I'll have to go with Carl on this one.....been running glued on pieces like you describe for years...no problems and the rivets can be a pain in the back side. I gave up on mine, the rivets were so hard you couldn't set them and the little tool I bought with them was useless/worthless. Your choice though.
Sir Searchalot
Sir Searchalot
I did see that Classic also had SS.
Sir Searchalot
Sir Searchalot
Blind rivets have a stick out. How does that work on a division bar where both sides need flush? Also aren't the rivet sizes predetermined by the hole and countersink sizes?
I only know TF. Maybe AD is different, just curious.
I used the tool and rivets that batamos posted.
After screwing-up one into oblivion, all the rest were quite easy to install.
I know what to do on the truck I should be restoring.
Fox Offline
Tim, I used the classic rivets and I found the installation to go fairly smoothly. Like Tim said aw well, i screwed up the first rivet (not in the frame though, it was on my vise) and then got the feel for the tool and it went easier after that. One good thing about the kit was that it came with a couple extra rivets and I suspect it was exactly for this reason!
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
It's been a while, but there must be space on the backside. The channel felt sits where it is supposed to and I have no window bind. I must've checked fitment before I used them.
Sir Searchalot
Sir Searchalot
That would sure be a lot easier. I will check that method next time. Is that the head side? I was thinking of the upset end stick out. Must be clearance as you say.
Yes.
