4 members (NJC, fonz8261, Southerntruck, J Lucas), 141 guests, and 3 robots.
Topics128,089
Posts1,056,442
Members48,443
#130103 01/27/2005 3:01 AM
i have a 42 chevy i would like to make a daily driver out of it but at same time make it modern with disk all around and a 350 motor.with early 90s pickup 5 speed in it do i have to chang the front clip to do disk.
ya I know a few rednecks.Thay all drive chevys to,
Proud member of the Old Dominion Stovebolt Society
AND A MARINE
trucks range from 1942 1/2 ton to 1965 fire engine
#130104 01/27/2005 5:10 AM
No.
You can put disk brakes on the existing front axle. I've got disk brakes on the front of my truck with the original straight axle.
#130105 01/30/2005 7:38 PM
Just my opinion,I am sure someone will say I am wrong.Sub frame it or put an M2 frontend in it.It will drive and handle 100% better than with the stock suspension.
#130106 01/31/2005 4:29 PM
I've got a Mustang II front end on mine ... a dual master brake cylinder with disc brakes up front and drums in the rear. No complaints -- it drives and handles beautifully and stops real nice.
Note: I don't know how high your brake pedal comes up out of the floor, but mine was REALLY high ... I cut 3 inches off it and it was so much easier to brake I couldn't believe it!!! Removing 3 inches gave better leverage when stepping on the pedal.
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
#130107 01/31/2005 9:28 PM
Z
Z Offline
Yeah I cut 2 1/2" off mine and welded the pedal back on offset to the left an inch. Still was having problems finding a seat that felt comfortable getting from the throttle to the brake. So-o-o-o bit the bullet, threw some more money at it and put in a Roddoors seat and interior. Gray tweed, looks and feels nice, now for a carpet? Zeke
The Amish Connection
51 Chevy 1/2 ton 5 window,Vortec hotrod, no horse
#130108 02/04/2005 9:01 PM
Ditto on shortening up the brake pedal shaft.I had to cut mine,but I cant remember how much I cut out.
#130109 02/19/2005 6:45 PM
You can put disc brakes on the back if you change out the rear axle to one that was disc-brake equipped. But then get the master cylinder for it too and convert it to power brakes.
A lot of modern trucks use rear drums and front disc. Nothing wrong with that set up.
52 GMC 3/4 ton pickup
68 Big Block Vette
68 455 Firebird
#130110 02/20/2005 1:21 AM
O K I am old. I dont have any argument with any of the above but if you want a late model truck why not just buy one? The old shoe brakes will stop just fine if they are in good condition. I have seen them lock all four wheels in a panic situation. Not trying to start an argument. Just my opinion. Opinions are like noses, everyone has one.
I like old trucks
#130112 02/20/2005 2:43 AM
Quote:
"O K I am old. I dont have any argument with any of the above but if you want a late model truck why not just buy one? The old shoe brakes will stop just fine if they are in good condition. I have seen them lock all four wheels in a panic situation. Not trying to start an argument. Just my opinion. Opinions are like noses, everyone has one."
...Beeeecause modern trucks don't look like stovebolts. With the possible exception of the SSR and I'm not sure that really IS a truck.
68 Big Block Vette
68 455 Firebird
#130113 02/26/2005 6:59 PM
THAT'S A TRUCK!?!???
hahaha
GO RANGERS grin
Photos Updated so check them out!
#130114 02/27/2005 2:58 AM
Before planning the drivetrain out, you need to work on the seat and pedal situation. My '37 is about the same as your '42 as far as cab size goes. I am only 5'11" and find the seating very tight. I used the original seat. The very upright position gets pretty hard on your back after a little while of driving. You really need the seat to recline a bit, so finding one that looks good and fits is a tough job. I had four or five different bucket seats, trying to get one that felt good. I finally gave up and went original.
My truck is not 100% original, it has disk brakes on the straight axle with original reproduction springs front and rear and a late model rear axle. The engine is a 250 ci with a turbo 350 automatic transmission. I can cruse all day 65 to 70 mph and still get 19 mpg. Wind is a big problem at speed due to the high center of gravity and design of the truck. You will get tired of fighting it. Braking is also a problem. I have a valve on the rear to limit the quick lock up the tires, again due to the weight of the truck and the design of the springs. I fear a high speed stop, say from 70 mph. At, in town speed, no problem, stops straight and quick. My truck weighs in at 3300 lbs with me in it and 18 gallons of fuel. Its split almost 50/50 front and rear with 1680 front and 1620 rear. I did not lower the springs or drop the axles. I did remove a few leafs and add teflon liners to soften the ride which may have hurt the handeling somewhat. Its a trade off you have to make if you want a decent ride. With new stock springs, you better have a tight seat belt on, because you are going to get bounced around!
Replacement parts are a consideration to. I planned my drivetrain around a 1973 Camero. The engine, transmission, rear axle, and all of the brake componets are all from the same car. I can get parts from any store in any town no matter where I am. There is not a part on the truck, other than the radiator, that will strand me on the side of the road for very long!
Do I drive my everyday, No! I can't afford the insurace for a everyday truck, even if I could I wouldn't. I like the special weekend drives. To drive it everyday would make just another truck on the road. Joe
