2 members (mick53, klhansen), 118 guests, and 0 robots.
Topics128,113
Posts1,056,277
Members48,439
#1300918 02/27/2019 10:26 PM
Which is preferred when it comes to protecting your fuse block? Most FLAPS don't carry fusible links especially 14 gauge type. Most vendors state as a general rule....10 gauge wire is protected by a 14 gauge fusible link. How many of you have your fuse blocks protected in this fashion?
I don't see any overload protection when the previous owner upgraded to a 12 circuit EZ wiring harness? In fact, with other hotrods I've owned over the years I can't recall exactly what I had or not.
Riding in the Passing Lane
A fuse in a critical system is dangerous. If you have an intermitant short or a surge the fuse will blow instantly. You could be going down the center lane on the freeway & every thing shuts off. Or a dark 2 lane & the lights go out. With a fuseable link it would buck & flicker & not go off unless it was a continous dead short. Fuses are fine on the heater, radio etc.
George
1972 Chevy c10 Cheyenne Super
Sir Searchalot
Sir Searchalot
I use fusible links on the big incoming wires from battery. Fusible links are available at most FLAPS. 14 is very common. They are sized 4 gauges smaller than the protected wire. For a 10 it's: 11 12, 13, 14 as you said.
click Dunlap and Jasper
Thanks fellows. I'll head down to my local O'Reilys and check it out.
When I was building my $100 wire harness, I bought a roll of fusible link along with about $300 worth of other electrical parts.
Another quality post.
Real Trucks Rattle
Sir Searchalot
Sir Searchalot
I have proven to myself that doing my own harness is same or more cost than buying one.
Doing just parts of the wiring is cheaper DIY however.
My problem is I like to buy way more "stuff" than I need, then I can't find it, so I go buy more. My home made wire harness works just fine, even as ugly as it is.
Real Trucks Rattle
