| | | Forums66 Topics128,114 Posts1,056,283 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2018 Posts: 473 Shop Shark | | Shop Shark Joined: Dec 2018 Posts: 473 | Which is preferred when it comes to protecting your fuse block? Most FLAPS don't carry fusible links especially 14 gauge type. Most vendors state as a general rule....10 gauge wire is protected by a 14 gauge fusible link. How many of you have your fuse blocks protected in this fashion? I don't see any overload protection when the previous owner upgraded to a 12 circuit EZ wiring harness? In fact, with other hotrods I've owned over the years I can't recall exactly what I had or not. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | A fuse in a critical system is dangerous. If you have an intermitant short or a surge the fuse will blow instantly. You could be going down the center lane on the freeway & every thing shuts off. Or a dark 2 lane & the lights go out. With a fuseable link it would buck & flicker & not go off unless it was a continous dead short. Fuses are fine on the heater, radio etc. George
They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I use fusible links on the big incoming wires from battery. Fusible links are available at most FLAPS. 14 is very common. They are sized 4 gauges smaller than the protected wire. For a 10 it's: 11 12, 13, 14 as you said. click Dunlap and Jasper
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Dec 2018 Posts: 473 Shop Shark | | Shop Shark Joined: Dec 2018 Posts: 473 | Thanks fellows. I'll head down to my local O'Reilys and check it out. | | | | | Joined: Dec 2002 Posts: 3,441 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,441 | When I was building my $100 wire harness, I bought a roll of fusible link along with about $300 worth of other electrical parts.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I have proven to myself that doing my own harness is same or more cost than buying one.
Doing just parts of the wiring is cheaper DIY however.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Dec 2002 Posts: 3,441 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,441 | My problem is I like to buy way more "stuff" than I need, then I can't find it, so I go buy more. My home made wire harness works just fine, even as ugly as it is.
