| | | Forums66 Topics128,100 Posts1,056,513 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2012 Posts: 163 'Bolter | | 'Bolter Joined: Dec 2012 Posts: 163 | I am going to install 2 point seat belts in my 51 as an afterthought and I have read all the posts on this but I still am unclear of the bolting location of the OUTBOARD belts. Should they thread between the seat cushions inside the seat frame or around the outside of the seat frame? (obviously you could see the mounting bolt this way but that doesn't bother me) Thanks, Howard | | | | | Joined: Jun 2016 Posts: 182 'Bolter | | 'Bolter Joined: Jun 2016 Posts: 182 | I threaded mine in between the cushions on my 1950 3100. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Jan 2013 Posts: 2,234 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,234 | I installed 3 point harnesses on the outside. I’m ugly enough and don’t need to slam my face into a metal dashboard! It was very easy to do.
Chris | | | | | Joined: Dec 2012 Posts: 163 'Bolter | | 'Bolter Joined: Dec 2012 Posts: 163 | Thanks for the responses and photo. It looks like I could mount them either way. I will decide what works best for me.
Howard | | | | | Joined: Dec 2014 Posts: 678 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 678 | If you route them on the outside of the seat frame they will fall out the door and crash to the running board every time you get out of the truck.
But I see that this is a fairly old post so he's probably already done it by now.
1951 Chevy Panel Truck
| | | | | Joined: Jan 2002 Posts: 2,842 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,842 | Yes for inside the frame.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
