| | | Forums66 Topics128,185 Posts1,057,294 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 2,896 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,896 | Hiya fellow bolters', I am trying to figure out what year this radiator is from, that is in my 1965 Chevrolet C10 pickup. I have some photos and measurements posted here: 01/28/2019 — radiator - 9 pictures I think it is from the next body style chevy trucks(67-72), but I'd appreciate it if any of you can help me find out the year or parts numbers, etc.. It started leaking again, I took it out and it was a little wonky trying to find a good active radiator repair shop in my area. I finally found one and it is back in the truck now, but I'd really like to know what it is, as this is the 2nd or third time I've had it repaired, so I guess eventually I will have to get a new one! Thanks a bunch for any information you can provide. -Woogeroo | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | Woog, The pictures show a radiator with a fill cap at the top driver side. The top hose connects on the PS. The bottom hose connects on the DS. I had a FORD radiator like that.
My Chevy Harrison radiator for a the L6 is tall and narrow and the top hose is on the DS. The bottom hose is on the PS. The fill cap is off center to the PS.
The 1960-66 C10 trucks with a V8 had a short wide radiator that rested in saddles mounted on the upper rail of the frame crossmember. The L6 engines had the tall narrow radiators.
Jay
| | | | | Joined: Feb 2002 Posts: 2,896 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,896 | The fill cap on this radiator is on the passenger side, next to the battery.
That side of the radiator faces the engine.
Thanks for the reply.
| | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | I think what Lugnutz is saying is the fill cap is in the top tank. That would put it on the drivers side.The bottom tank is on the left in picture. Your picture shows the radiator on its side.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
| | | | | Joined: Feb 2002 Posts: 2,896 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,896 | So, it would seem that it may be a 1973 and up Chevy Radiator.
Maybe a 1973-1977 based on the tanks, maybe with a different core... I updated the latest info. on the link above.
Hmmmn.
-Woog | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | I see now. It’s a cross flow radiator. So the fill cap is on the PS. All of my 60-66 radiators have been vertical flow, so I assumed . . . . . I have no clue. I suppose you could start comparing Google images, but even then . . . | | | | | Joined: Feb 2002 Posts: 2,896 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,896 | Lugnutz, yeah I've seen the original ones in 60-66 engine bays at car shows. Which is why I was pretty sure mine was not original. The top mounts/brackets that hold it in place for the one in my truck are the next body style tho', as I bought some rubber pieces for them one time. a photo of the radiator installed... The 60-66's I've seen have that center mount/bracket that goes up and over the radiator. Lakeroadster found a image of a '73-'77, the tanks look the same, but the width seems wider, hence maybe it was custom. I dunno. details in the link here: original link - updated with responsesThanks for the reply! -Woog | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | I don't know about the cross flow radiators but all the GM vertical flow Harrison radiators I've seen had the year of manufacture embossed into the top tank.
Evan
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | My Chevy car radiator is as ‘coilover’ stated. The month in letters plus the build year are on the top tank facing forward. Important in keeping a vehicle original. Costing me over $800 to do just that on the radiator.
| | | | | Joined: Feb 2002 Posts: 2,896 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,896 | There is very little original about my engine bay, hence my issues trying to identify things when they break.  | | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | hi Woogeroo, did you have any luck with your radiator quest? i did some google image searching, and this is what i found...
it looks to be some generic GM / chevy radiator, not an OEM for any vehicle in that time frame, (but i gave up on OEM radiators pretty quick as cross flow seems rare for those years outside of British designs) there are many options in this style online to choose from between $150-500 range still made new to this day, however they are mostly all aluminum now. based on the dimensions and make/model you found it in, i would believe it to be an early version of one of either common sizes made today 26 x 19 or 26 x 16 available with top passenger fill cap cross flow design upper left (driver) inlet 1-1/2 inch lower right (passenger) outlet 1-3/4 inch
it is unfortunate that all will mount slightly differently from each other i suggest finding a radiator shop and they would perhaps be able to suggest a solution, or go back to an OEM radiator -s
| | | | | Joined: Feb 2002 Posts: 2,896 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,896 | 2ManyTrucks,
thanks a bunch for the information.
I did have my old one repaired, but I was trying to find out for the time when it can not be repaired anymore.
I think that was the 3rd time I have had it out to fix it, so I suppose eventually I will have to get a new one, hence my trying to determine what I have, while I had it out of the truck to take photos and measurements.
-Woog | | |
