0 members (), 254 guests, and 2 robots.
Topics128,094
Posts1,056,066
Members48,433
#12961 02/14/2002 2:16 AM
I'm in the process of rebuilding a 1958 235 engine. I'm trying to remove the camshaft. I already removed the two screws that hold on the thrust plate and the camshaft slides out about 1/2 inch, then stops. It's hitting something, but I don't know what. What should I be looking for, or what did I forget to remove?
Thanks for your help
Mario
#12962 02/14/2002 3:34 AM
Did you remove the lifters? This is what it sounds like to me. You may have to remove the distributor also. If it were me I would do this anyway because you will have to time it after the new cam is put in.
kdot em3
#12963 02/14/2002 3:37 AM
kdot em3
#12964 02/14/2002 4:22 AM
Anonymous
Unregistered
Anonymous
Unregistered
May have to remove fuel pump as well.
#12965 02/14/2002 5:44 AM
Hmmmmm,,,,, I seem to remember something about crankshaft position as well as what is listed in the above posts!
#12966 02/14/2002 6:41 AM
After the lifters are pulled out from the cam, the distributor and fuel pump are out, line up the timing marks on the crank & cam gears. One of the crank counterbalances won't clear the cam journal unless everything is just right.
Fred
52 3600
69 C-10
