| | | Forums66 Topics128,095 Posts1,056,077 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#12961 02/14/2002 2:16 AM | Joined: Dec 2000 Posts: 34 'Bolter | | 'Bolter Joined: Dec 2000 Posts: 34 | I'm in the process of rebuilding a 1958 235 engine. I'm trying to remove the camshaft. I already removed the two screws that hold on the thrust plate and the camshaft slides out about 1/2 inch, then stops. It's hitting something, but I don't know what. What should I be looking for, or what did I forget to remove?
Thanks for your help Mario | | |
#12962 02/14/2002 3:34 AM | Joined: Dec 2000 Posts: 64 Member | | Member Joined: Dec 2000 Posts: 64 | Did you remove the lifters? This is what it sounds like to me. You may have to remove the distributor also. If it were me I would do this anyway because you will have to time it after the new cam is put in.
kdot em3
#12963 02/14/2002 3:37 AM | Joined: Dec 2000 Posts: 64 Member | | Member Joined: Dec 2000 Posts: 64 | Did you remove the lifters? This is what it sounds like to me. You may have to remove the distributor also. If it were me I would do this anyway because you will have to time it after the new cam is put in.
kdot em3
#12964 02/14/2002 4:22 AM | | Anonymous Unregistered | | Anonymous Unregistered | May have to remove fuel pump as well. | | |
#12965 02/14/2002 5:44 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Hmmmmm,,,,, I seem to remember something about crankshaft position as well as what is listed in the above posts!
#12966 02/14/2002 6:41 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | After the lifters are pulled out from the cam, the distributor and fuel pump are out, line up the timing marks on the crank & cam gears. One of the crank counterbalances won't clear the cam journal unless everything is just right.
Fred 52 3600 69 C-10
