1 members (Rusty Rod),
80
Mod | | | Forums66 Topics128,127 Posts1,056,680 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2004 Posts: 543 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 543 | I've come across a complete '71 Cad CdV in great shape (from the doors forward!). It got hit hard in the left quarter and spun the right quarter into a pole, but the accident didn't affect the drivetrain. Does anyone make brackets to fit the complete 500 setup in a '41-'46? I'm going with a Mustang IFS and a F-ord 9" rear on the stock Chevy frame. Suggestions???
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass. Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
| | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | hmn. too much power...
hehehe
-W | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | That kid's project is wild.
I have a Cadillac 4.5 ltr which runs pretty well. I've been wondering about using it as the power for an S-10/Astro based all-wheel-drive AD pickup.
Probably just a crazy thought, but its a Cadillac in an old truck, so I had to share it here.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Feb 2000 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2000 Posts: 132 | i think you're gonna find the front sump pan is gonna give you problems so start looking now for a eldo pan and pickup tube and i think you'll need the dipstick+tube.
might want to look at 318/340/360 mopar engine mounts OR build a plate off the engine to accept a chevy mount(use a HD mount with the locking tabs)
i miss obscene phone calls...
| | | | | Joined: Feb 2000 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2000 Posts: 132 | trust me on this one. eldos have a rear sump pan, devilles have a front sump pan.
| | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | and 425s have the sump 3/4s back. | | | | | Joined: Apr 2004 Posts: 36 Member | | Member Joined: Apr 2004 Posts: 36 | I've replaced those motors in Caddys and they are "HEAVY"! If you haven't thought of it already it is going to make your truck way front end heavy. They also require a large amount of cooling so that will have to be upgraded also.
I'm not trying to rain on your parade, just my thoughts.
Larry | | |
