4 members (TUTS 59, 55shaker, elhippie64, Bill Hanlon), 66 guests, and 3 robots.
Topics128,128
Posts1,056,685
Members48,452
#129537 07/03/2004 4:50 PM
I've come across a complete '71 Cad CdV in great shape (from the doors forward!). It got hit hard in the left quarter and spun the right quarter into a pole, but the accident didn't affect the drivetrain. Does anyone make brackets to fit the complete 500 setup in a '41-'46? I'm going with a Mustang IFS and a F-ord 9" rear on the stock Chevy frame. Suggestions???
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass.
Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
#129539 07/07/2004 10:11 AM
Socket Breaker
Socket Breaker
hmn. too much power...
hehehe
-W
#129541 07/20/2004 6:19 AM
That kid's project is wild.
I have a Cadillac 4.5 ltr which runs pretty well. I've been wondering about using it as the power for an S-10/Astro based all-wheel-drive AD pickup.
Probably just a crazy thought, but its a Cadillac in an old truck, so I had to share it here.
#129542 07/20/2004 12:30 PM
i think you're gonna find the front sump pan is gonna give you problems so start looking now for a eldo pan and pickup tube and i think you'll need the dipstick+tube.
might want to look at 318/340/360 mopar engine mounts OR build a plate off the engine to accept a chevy mount(use a HD mount with the locking tabs)
i miss obscene phone calls...
#129545 07/21/2004 1:36 AM
trust me on this one.
eldos have a rear sump pan, devilles have a front sump pan.
#129546 07/21/2004 2:22 AM
Z
Z Offline
and 425s have the sump 3/4s back.
#129547 07/21/2004 3:58 AM
I've replaced those motors in Caddys and they are "HEAVY"! If you haven't thought of it already it is going to make your truck way front end heavy. They also require a large amount of cooling so that will have to be upgraded also.
I'm not trying to rain on your parade, just my thoughts.
Larry
