Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (Wickedbass, tclederman, Youngin' Tut 59, UtahYork, Woogeroo), 37 guests, and 5 robots.
Topics128,010
Posts1,055,303
Members48,419
#1293700 01/05/2019 8:57 PM
This was hidden under a lot of bondo. The seal retainer and seal were covered and it was pretty ugly. I'm thinking a small patch that will be mostly hidden under retainer. My welding is getting better but it's still not pretty. I'm still a beginner, and advice would be awesome.
Matt_Texas #1293701 01/05/2019 8:58 PM
The outside bottom still looks solid, no bondo or bubblingbof the paint.
Matt_Texas #1293705 01/05/2019 9:21 PM
Very likely, there will be internal pits on the outside skin. You may burn thru when welding at the seam, but you should be able to get it fixed up. You should consider sandblasting first before attempting repair. That will show the true nature of the rust extent.
I don't know of an inner door patch available, which would be your best option if you can find one.
Good luck.
Matt_Texas #1293823 01/06/2019 5:45 PM
Good place to do patch practice, too, as the area can't be seen unless the door is open.
Matt_Texas #1293873 01/07/2019 12:48 AM
I was thinking the same thing lol
Matt_Texas #1293874 01/07/2019 12:51 AM
Try to do your butt weld at one of the lateral folds in the bottom of the door. This will help control warping.
