0 members (),
132
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | Just what is it?What type of finish does it leave.I think it is used on the undercarriages of cars and trucks.Is it a product you can buy and apply it yourself?THX for any info. Dale | | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | Do a search in the Paint & Body shop forum. One result: http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=4;t=001286#000000 | | | | | Joined: Nov 1995 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 1995 Posts: 1,159 | Dale,
Even better ... do a Google search from the index page (first page) of the site. There are a lot of references to POR 15 throughout the site -- including some testimonials from folks who used it and commented about it in their gallery submission.
Then you can ask some of them directly with their email address.
Peg
~ One of many.
| | | | | Joined: Feb 2000 Posts: 203 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 203 | It's my understanding that to use POR you must have rust as it's a convertor. If you have a painted or bare metal surface on either side it doesn't work as well. Zero Rust on the other hand works on all of the above ... rust, bare metal, paint and bondo (fibreglas). Here's a picture of my truck totally painted with the stuff. The Toad | | | | | Joined: Sep 2004 Posts: 26 Junior Member | | Junior Member Joined: Sep 2004 Posts: 26 | FatFenders,
Did you clear coat The Toad after applying the Zero Rust? That's the kind of finish I want for my '54. Kinda of a satin... | | | | | Joined: Apr 2004 Posts: 543 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 543 | Fat, did you spray or brush that on? Once I strip the boys' '46, that might be the look we're looking for!
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass. Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
| | | | | Joined: Nov 1995 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 1995 Posts: 1,159 | Here's a tech tip on Zero Rust that might be helpful, too. Peg
~ One of many.
| | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | THX for the info,I will check it out. Dale | | | | | Joined: Nov 2002 Posts: 2,763 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,763 | While we have used POR-15 for rust problems (and very satisfied with the results); we normally use it for an entirely different function.
Very early in the automotive industry, carburetor floats were made of cork, and then coated with orange shellac to seal the cork. Modern fuel will cut orange shellac about like a heated knife will cut butter! We dip the new floats in POR-15, remove the drips, and allow to air dry. So far, have never had a float failure using this stuff.
Just be sure to read the precautions which come with the product. If you allow any to dry on your skin, you will wear it for weeks!
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Feb 2004 Posts: 60 Member | | Member Joined: Feb 2004 Posts: 60 | | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | j0ftheworld,THX for that site it looks really interesting. Dale | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | you might check out eastwood company they have a new product out that is supposed to be a miracle worker where rust is concerned. eastwood.com
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | I tried POR-15 on a mildly rusty surface. After it dried, I was able to peel it off in sheets, and the rust underneath looked no different.
I don't think the stuff works. I think it's a rust encapsulator, not a rust neutralizer. And I think it's overpriced.
How about just sanding and painting with a good enamel paint? That's always worked for me.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | |
