10 members (klhansen, papas52, baldeagle, 1955 1 Series, KEVINSKI, Hotrod Lincoln, TUTS 59, Gdads51, Dusty53, Lonnie), 178 guests, and 3 robots.
Topics128,165
Posts1,056,999
Members48,458
My nephew purchased a replacement 1963 230 c.i. motor. Removed the tranny to flywheel in order to mount it on engine stand. Now wants to perform compression check. Is that possible and if so how? Thanks.
3B Offline
Hy beltfed, Merry Christmas, if the stater mounts to the engine block you might be able to do a compression on the engine stand, BUT the stand must be a strong stable one. I would prefer you take the engine off the stand and block it on the floor and do the compression test there.
H Online: Content
You will need to have a flywheel or a flex plate bolted onto the crankshaft, and the starter in place. I can't think of an effective way to spin the crank fast enough otherwise. How about doing a cylinder leakdown test instead, where air pressure is put into the cylinders? You'll need to figure out a way to lock the crankshaft for each compression stroke, maybe with a piece of steel bar bolted to the crank and locked against the engine stand.
I told him he “put the cart in front of the horse”, but he takes after his uncle (me). I’ll pass this info along. Thanks.
If the stand is a four wheel type, doing the compression test shouldn't to much trouble. Support the front of the engine with 2x4 cut to length, add a flywheel and starter, hook up a battery and temporary starter push button. Remove all spark plugs and have carburetor wide open ( no fuel hook-up ). Spin the engine for three to four compression stroke on each cylinder with gauge screwed in. Add motor oil to each cylinder, rotate it slowly by hand to spread the oil out, then do the compression test again on all cylinders same as before. The oil will "seal " the rings slightly especially if the engine has sat for awhile. The actual number isn't as important as the difference from one to the other.
There will be not torque on the test stand as the engine spins, and with a good battery and starter, the engine should spin quite fast.
Second vote for cylinder leak down........simple especially in this case and gives more info on the engine components.
https://www.pegasusautoracing.com/document.asp?DocID=TECH00137
Crusing in the Passing Lane
Third.
Ed
