6 members (KEVINSKI, 1955 1 Series, UtahYork, Jman, Southerntruck, klhansen), 113 guests, and 2 robots.
Topics128,101
Posts1,056,523
Members48,448
Hi there,
I have a 1968 GMC 3500 that has 1.5 ton axles underneath it (custom ordered).
https://photos.app.goo.gl/AKWSRWcY22uMfzuk7
https://photos.app.goo.gl/yJQismAyiZVuJEAx6
https://photos.app.goo.gl/wyekmmTDKg3XVcve9
https://photos.app.goo.gl/wg2U76NcP3xPGjPW7
I am looking for modern non-split rim wheels.
They are ten lug, center hub is 5.25"
Any help appreciated.
thanks
Try this thread and the tech tip link contained within.
https://www.stovebolt.com/ubbthread...els-and-tires-what-to-do.html#Post867617
More modern 19.5” wheels like from a P30 Chassis or 3500HD, all with 10 lugs like yours is probably your best bet. Check that they fit over your brakes before buying.
Are the originals 18”?
•1952 Chevrolet 3800 pickup
---All pictures---
Fantastic, I’ll give them a shot.
Thanks grigg
Did you find the wheels you needed ? I had a '72 C/40 with the one piece 20" rims. Might know of some 19.5" off of a '78 Short Bus ... 10 lug but don't know the pattern for sure.
1954 4400
1954 3800
Jim D.
'41 Chevy 1-Ton Pickup/dump...292" 4-speed w/Ranger OD ... Newest Truck
'54 Chevy 3800 Dump........New Truck!
'54 Chevy 4400 flatbed/dump, Gone to my brother-in-law
'13 GMC 1500 daily driver ... 5.3 6-speed auto just turned 13k miles
'01 Chevy 2500hd, might be my new daily driver ... 6.0 / 4L80-E
I'm in the same boat with my '54 4400. I want to keep the taller tires so the modern 19.5's are not an option for me. I've called custom wheel makers and I've found one that'll make what I want but they're waiting on the blanks to come in which will be 3-4 months. I've also looked at wheel adapters. Not sure what gear you're running but that's one of the main reasons I want to stick with the taller tires. I have a 6.50 rear end. If you find something, please post.
1954 Chevy 4400
Crusing in the Passing Lane
A good source for GM 5/10 axles is downtrodden motorhomes, seems like a lot of dead or nearly dead ones around here, best clue is wheel bolt pattern. Most have 19.5 wheels/tires though. 22.5's occur on late '50's early tubeless tires
Ed
