0 members (),
108
8
Mod | | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | I installed a dual-stage power brake unit when my original master cylinder failed on a hill. I bent new hardline to the front, bled the system, and tested. It worked perfectly, stopped the 3.5 ton panel on a dime. I drove the truck to my buddy's shop to replace the sheetmetal damaged in the brake failure, and we ended up doing a major resto. For the better part of a year, it sat in the yard while we worked on a cure for it's cancer.
Here's where it gets strange: When I put it back on the street, I noticed that the brake pedal would stay down when depressed with the brakes locked. I can pull the pedal up and the brakes release, but the only way to make the thing behave normally is to remove the vacuum hose and cap the booster.
So what makes my booster stick with full pressure? I need to get this sorted, as stopping without the booster is a total b1tch. | | | | | Joined: Feb 2000 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2000 Posts: 132 | sounds like you need a return spring on the pedal. had to do it on my COE as it did the same thing. go get ya a universal clutch return spring from a parts store..
i miss obscene phone calls...
| | | | | Joined: Mar 2001 Posts: 259 Member | | Member Joined: Mar 2001 Posts: 259 | I would first try just replacing the Vac check valve going into the booster. If that doesn't cure it then you probably developed a tear in the booster seal and just need to replace the booster.
Joe
| | | | | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | I replaced the return springs for both brake and clutch pedal, but that didn't change anything. I think I'll take it into the local brake shop and have the booster/check valve tested.
I really hate spending money I don't have, and I was hoping this would be something I could solve. | | | | | Joined: Dec 2002 Posts: 3,447 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,447 | did you put in a proportioning valve too? Check that the rod isnt sticking.
