6 members (Toadwart, FishinToms53, UtahYork, Southerntruck, homer52, 1 invisible), 160 guests, and 2 robots.
Topics128,087
Posts1,055,999
Members48,430
Junior Member
Junior Member
Where do I begin on converting my 52 1/2 ton to power steering? I've heard certain power steering pumps from certain old cars will work but do not know particulars.
Brian Chaney
The easiest way is to put a knob on your steering wheel.
I agree, hard to find anymore cause i guess the government said they were dangerous...I've got a beaut off an old farm tractor
I've been pursuing an answer to the same problem on my '59 Apache solid-axle P/U with drag-link steering. I currently have two potential solutions. 1) Use a C-3 Corvette power ram set-up with the valve/sensor hooked to the pitman arm and running to the driver's side spindle replacing the old drag-link. The hydraulic tubes would run to the power ram, which would run from the frame to the center of the cross-linkage. 2) I discovered that the '78 Dodge truck P.S. came in regular rotation and reverse-rotation. If one took a reverse-rotation box (like a Cardone 277515) and turned it 90 degrees such that the pitman shaft ran through the frame rail like the original box (at least on mine), then it would function as a drag-link box with the pitman arm hanging downward. This would require fabbing up a new mounting plate running at right-angles to the frame rail, but if you're handy it could work well. To turn right (at least on mine), the drag-link has to move to the rear, which would be counter-clockwise rotation of the pitman shaft. Good luck!
Apache Kid
LT Offline
pirsch, go to www.brotherstrucks.com or www.cclassicperform.com. the latter is a ram type and pricey, 699.00 but this should be a long term investment. i have had to convince myself of this many times because i tend to be on the frugal side (cheap) hope this helps. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
2017 Buick Encore
See more pix
sorry again my catalog is 4 yrs old now the kit is 899.00 WHEEEEEEEEEEEEEW!!!!!!!!!
2017 Buick Encore
See more pix
Don't the Toyota 4x4 boxes mount the same as the AD boxes? I've seen then recommended for Furds, but couldn't understand why not for Chevy's.
I have one of them knobs and it works great,, one of those dice type,,,,,,hey cletis,, willy is coming to Ft. worth the fourth of July along with Dylan and some others,,,,,boy that place will be up in smoke..
Redryder pix
My Hotrod
